Rear defrost rusting
Saejin
Gene
Colorado Springs
JLUR - Firecracker Red
ok, not sure if this has been covered or is the cause with so many rear defrost systems not working but as I was cleaning up my Jeep I noticed the rear window where the defrost system is applied to the glass...well it’s rusting.
Winter is over, so I don’t have a way of checking to see if mine works or not. Just checking to see if others are seeing the same issues. Pics posted.
Saejin
Saejin
Gene
Colorado Springs
Oh yeah...I don’t have any leaks on the back window and only cleaned it once after washing the Jeep. You can’t tell from the outside there’s an issue, but once you start inspecting each individual line you can see it go from normal to rusting to normal, etc. funny thing is where they sanded away the coating to connect the power on both sides...those areas are not rusting and it’s bare metal.
HiJinx69
Richmond, VA
2018 Wrangler Sahara Unlimited JL, 2014 Mazda 6, 2010 Honda Odyssey, Yamaha FZ-09
Yeap, same here.
subiescott77
Elgin, IL
2018 Jeep Wrangler JL Rubicon
Mine is the same, as is my other buddy with a JLUR. I know if I press the rear defroster, the switch LED lights up and stays on. I haven't actually tested to see if it truly works though as I got the jeep early May. At first I was concerned but is this even a problem or just how it was made?
Saejin
Saejin
Gene
Colorado Springs
Not sure. If it continues to rust and then shorts the system I would say it’s an issue. If it’s just cosmetic then I don’t care. Just wondering what long term issues may arise and if any hoping the warranty covers it.
subiescott77
Elgin, IL
Yeah and I'm not sure if rusting is the proper description. I'd say discoloration. I'll have to check with my dealer.
Saejin
Saejin
Gene
Colorado Springs
True. If I rub it with my finger I can remove the rust/color and it’s back to normal. Not sure if it will last though.
subiescott77
Elgin, IL
Well that's interesting. When you refer to the "rusting" part, do you mean the sporadic areas where there is a brighter silver sliver?
Saejin
Saejin
Gene
Colorado Springs
Well it looks like it’s supposed to be all white or silver but then there are these areas where it looks like rust. When I rub those rust areas it comes off and looks white again.
subiescott77
Elgin, IL
I'm interested to see if others share the same thing, along with their input.
trailcat
Tiger
NWA
Wrangler JK
Same here, can’t say if rusting or decolouration but for sure it’s fading and loosing its life.
Jeepsk8
Sierra Vista, AZ
2020 JLUR
To be honest, it is a heating element, it's probably burning off the coating. Not sure how hot they get, but copper doesn't rust, and residue is likely just bubbled up coating.
subiescott77
Elgin, IL
Is this something that's been seen before for anyone? I bought in early May and have no idea if anything truly works until this winter.
subiescott77
Elgin, IL
Update...
Dropped by my dealership today and looked at several JLs. All had random discoloration spotting throughout the rear defroster grid lines. None of the guys knew what the deal was and if it was supposed to be normal. The one service guy seemed to think it was burning too hot. I'm scheduled to go in soon for something else and theynsill test to determine if the defroster actually works.
JeepCares
Auburn Hills, MI
JL
Hello everyone,
If you are experiencing this concern - please send us a private message with additional details if you have not already.
Julie
Jeep Social Care Specialist
