Rear AC vent airflow?
Lightsped
Kennesaw/Acworth, Georgia
2021 Willys, 2017 Tacoma Off Road, Honda S2000.
Technology Research
Should the rear AC vents be putting out as much air as the front vents? When have the AC or heat on there is barely any air coming out of them. Have tried with AC in the various airflow modes (3rd knob on the right) on the controls.
Xcoaste
Ben
PA
2021 JLUR - Past - '13 JKU, '97 TJ, '93 YJ
You wont get as much air in the rear as in the front. I have to turn the fan speed up pretty high to feel it come out of the rear.
Retrograde
Michael
God's Country, Idaho
2020 JLSS, 1995 Chevy K2500
Arms Dealer
Yeah... they don't do much. Their sole purpose is to sell Jeeps to families...
Me: "Look Honey, it has air conditioning for the children."
The wife: "Squeeeeeee!"
Heimkehr
Pennsylvania
2021 JLU 2.0T
The HVAC tubing run to the rear seats, via the center console,* would need to be properly molded in an ever-decreasing circumference in order to provide increased air flow. IOW, it would need to mimic the ductwork leading from the furnace to the rest of one's house.
Having seen what said tubing looks like under a partially disassembled center console, it's evident that it's too wide leading up to and at the exit point to compress (and thus increase) the flow of conditioned air sufficiently to get anywhere close to what exits from the dashboard vents. With this in mind, I'm content with the air flow that the upper rear vents do manage to provide.
*Remember that there are other mouths to feed, also, in the form of floor vents under the front seats.
Lightsped
Lightsped
Technology Research
Never realized there were vents under the front seats? Are they putting out more air than the portion behind the console?
XJfanatic
El Paso, Tx
2020 JLU, 2020 JT, 2000 TJ
Under the front seats is for the heat/floor position up front.
mine put out pretty decent air for console a/c but nothing like a dedicated blower in other vehicles.
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
It's simply the result of the conditioned air following the path of least resistance.
For a well balanced system, 2 things are required. Velocity and volume. First is decreasing the size of the duct work to maintain air velocity. Second is adjustable butterfly valves at each split in the duct work. Choking down the airflow in the legs closest to the supply will ensure that enough volume is farther from the supply. I'm HVAC-R certified but never brought the knowledge out into the field. Nothing against that industry. Just simply got a much better offer to run a different business.
The Fixer
North Jersey
Teacher
I believe the rears work best with the switch set to dash vent only, not split between the dash and floor. My kids would let me know if they were too hot or too cold LOL.
Wbino
NJ
Just tell those in coach that air is only for those in 1st class. ?
Heimkehr
Pennsylvania
2021 JLU 2.0T
Yep. That's been true for every vehicle I've owned with rear vents, including the JLU.
I'm going to use that one. :)
