rain gutter rack mount, any issue?
Dadgummit
Jon
Anaheim, CA
2021 Rubicon Unlimited 3.6l -- 1966 Pontiac GTO Convertible
Centurion07
'MERICA
2019 Rubicon 2-Dr
You CAN put a lot of weight, especially static weight on the gutters. I've done it myself, even on the freedom panels.
Is it a great idea? Nope, because in the end, it's just little rain gutters holding it all together. This is true, regardless of any bolts or experience Ole_Congenial or Ole_Cuddly has to offer.
If you want strength, something like a Maximus-3 system works great, but it has trade-offs if you like running topless on occasion.
If you're just going to carry lightweight stuff, then just get something rated at 100lbs dynamic or more and you should be fine.
Boatbuilder88
New Jersey
'19 Wrangler JL
F-16 Engineer (retired)
Weight isn't the only issue to consider with gutter-mounted roof rails. Aerodynamic lifting forces and moments can be very high depending on the item (eg cargo box, kayak) being carried on the rack.
AndySpill
Andy
Pittsburgh
2018 JL Sahara
LukeDagny
Central PA
2021 JLUR
The Yakima racks I use mount the same way, which is the same as the Mopar racks. I may not have exceeded the 100# limit, but I'm close when I haul two Heritage 9.5 kayaks. The kayaks are supposed to weight 40# each, plus the weight of the racks.
I think whatever rack system you choose, stay under the weight limit and you'll be fine.
If you don't trust the OEM rain gutters, you can add some rain gutter brackets, if you don't mind drilling some holes into your top. I used these on a fiberglass truck cap to haul multiple canoes. The weight would have been well over 100# with these brackets.
https://www.etrailer.com/Accessories-and-Parts/Yakima/Y08002.html
BRuby
Chilling or working out at 60+
JLUR Benz Porsche-M Subie-M
It is seem quite expensive to find wrangler specific rack amount, so I want to build my own from aluminum extrusion parts.
Any issue with rain gutter rack mount, how much load does it take?
like this one
https://www.amazon.ca/gp/product/B0D31F3QBJ/ref=ox_sc_act_title_3?smid=A3V8KM657SOFDN&psc=1
Post this pic years ago. Using a Yakima gutter mount is fine. No stress cracks nothing. Take off the rack and you would never know what load was up there. This is around 150lbs or maybe a bit more static. 16' glass comp canoe plus 3# - 14' hard racing paddleboards comp and carbon. Bouncing on a heavily rutted with huge potholes FSR back to civilization. Highway probs was around 60mph for a few hours. So dynamic wind load was pretty massive with that much windage. But just tie it down properly - drive within reason - and you should be good. Not speculation or guesses or BS. Actual. Best not to exceed 60mph.
Jeep Wrangler JL rain gutter rack mount, any issue? 3681367C-1A23-4988-85AC-2A89457029AA
Centurion07
'MERICA
2019 Rubicon 2-Dr
Like others, I carried kayaks and SUPs. IF you can tie down your load to the hood, bumpers, whatever, you mitigate some of the lift forces.
Still doesn't get you around the weight limit or the chance to crack gutters - not the "best" idea, but it may work fine.
Jeep Wrangler JL rain gutter rack mount, any issue? 1000003786
rforbes
Raymond
Seattle, WA
2024 Wrangler Rubicon X 4xe
If I remember correctly Jeep says their gutter-mounted rack can hold a max of 100 pounds dynamic. That's including the weight of the bars. In other words: they can't hold much. At all.
And I am not sure I would even put that much weight up there.
IdowaJeeper
Travis
Eastside of Washington state.
2024 Wrangler UL Sport S 4XE, 2024 Ram 2500 Crew Cab Cummins on 35s, Kodiak ATV.
On my Tundra's Leer topper, I wanted a roof rack that was flat for hauling lumber, kayaks, and other longer items. Plus, I had a bad experience with wind noise and drag using basket racks in the past.
So, I bought some ladder racks and bolted them to the top, then found this rack for under $200...
Amazon.com: WILDROAD Car Roof Platform, Universal Roof Flat Rack 69" x 47" x 1.3" Heavy Duty Roof Rack Platform with Super Duty Bungee Cargo Net, Ratchet Straps and Anti-Rust Sealant Fits for SUV Truck Cars : Automotive
It works great! No noise and when you average 13mpg, not really noticing any decrease, lol.
Jeep Wrangler JL rain gutter rack mount, any issue? 20240224_153048
I'll have to check the dimensions of the JL's top, but will likely use the same rack mounted on good quality gutter mount cross bars.
No way will I ever have a rooftop tent, and usually just need to grab a couple of 2x6s or some other item that is over 5.5' long, so 150lb limit is fine.
LazyJL
Larry
2020 Rubicon, 2001 built XJ
Retired fabricator and mechanic
Our 2020 JLR has had a Maximus-3 through the roof, into the roll bar mount for three years . It has been trouble-free carrying two 14' sea kayaks down many rough roads, plus many leads of lumber.
It is a pain to install and eliminates easy removal of the top, it works for us,.
I bought the roof mounts and internal support pieces with rack or crossbars, Instead of commercial racks, Unistrut bars are used, allowing all sorts of mounts to be made and used.
IdowaJeeper
Travis
donmontalvo
Don
Livingston, TX
donmontalvo.com
2021 Jeep Wrangler Unlimited Rubicon (Snazzberry)
To be clear, I have first hand knowledge of an iKamper coming off a "big brand" roof rack system where six stainless steel screws pulled loose from their mounting. This is not my imagination nor is it a maybe. Check your system often.
The screws are designed to be fuses. Drive into a low overhang and your RTT gets knocked off your roof...but your roof doesn't get ripped off your Jeep.
I haven't read the whole thread, but I have the same goal as the OP.
