Radio Volume Output Issue (1/2 expected output)
paffemt
Chester County, PA
2019 JLU Sahara
I’ve had the volume drop to 50% once, but cleared itself after a couple of drives. Now the “no volume” issue has happened a few times. Each time I was on XM and switched to AM and audio came back.
Snayte
Nathan
Eau Claire, WI
2019 JL Sahara Hella Yella, 2017 Ram 1500 Longhorn
Does messing with the speed sensitive volume settings do anything? Just thinking that may be getting wacky.
MacombRoger
Roger
SE Michigan
2018 JLUR Ocean Blue
Solution Architect
there is an AMP upgrade at the dealers if you want to give it a shot.
TSB# 08-151-18
New firmware number 68331275AF
Wow. I get humming like sounds a lot. Especially when I stop moving. I wonder if this would help me.
TurpJL
MidWest
2018 JLU Rubicon manual - Ordered 3/3
JeepCares
Auburn Hills, MI
JL
Hi paffemt,
Please let us know via private message if you decide to have your dealer look into this. We would like to have this documented and connect you with a Case Specialist who will work with your dealer to help find a potential solution.
Lydia
Jeep Social Care Specialist
Rahneld
Ronald
Boston
JL Wrangler
I doubt the problem is this but I'll throw it out there. Your volume controls (dial/behind steering wheel) *can* (depending on radio) set up to 3 different volumes depending on what application (radio/Uconnect, etc.) the radio is running at any given moment.
I wonder if the system is stuck in a non radio volume control setting and users, when adjusting the sound level, aren't controlling radio sound levels but another application's sound level that's also displayed through the stereo system.
Chemy350
Atlanta GA
Mortgage Loan Officer
I have this problem.. have had it for months. I use Apple car play and stream Apple music. 9/10 songs played, come in at half volume, then randomly a song will play at full strength and scares the crap out of me :CWL:
JeepCares
Auburn Hills, MI
JL
Hi Chemy350,
Sorry to hear you are experiencing this as well. We suggest having your dealer inspect this concern if you have not done so already, as they are in the best position to assist. Let us know via private message if you decide to have your dealer look into this and we can escalate a case on your behalf for an additional layer of assistance.
paffemt
Chester County, PA
2019 JLU Sahara
Interesting theory, but when my Jeep was at low volume, even the GPS voice was low as well (I have speed warning turned on and the unit thinks the road the dealer is on is 35 not the posted 55).
Rahneld
Ronald
Boston
JL Wrangler
Noted sir. :)
bem1
Blake
lantanapcguy.com
2018 JL, 2024 JL
Same here. Does not matter if I am on Sat, FM, AM, BT, USB, Phone. The volume is the same. However, the button click tones are really loud...
offset_98
Tampa, FL
2019 JLU Sahara, 1993 Nissan 300ZX, 2015 Subaru Outback, 2011 Toyota Sienna
Well, finally experienced this myself tonight. 2400 miles, doors off. Worked fine all day today cruising but this evening, nope. Pulled the #97 fuse and re-seated it. That worked. Hopefully this doesn’t become a regular thing.
TurpJL
MidWest
Leaving my vehicle at the dealer with no doors and tops is problematic due to summer rain showers..
is disconnecting the cables to the doors enough to simulate no doors?
Also, a current test I am doing which has been successful for the past week is turning the jeep to accessory and letting the radio come on before starting. I am not sure if this is helping or I am just lucking out.
TurpJL
MidWest
From your description, you have a 2019, correct? I was hoping it was only 2018s. Are you manual or automatic transmission?
