Did you just wire it to a switch or pick up off some sensor on the jeep already?
I just wired it to one of my AUX switches. I only run it when off road in 4Lo.Did you just wire it to a switch or pick up off some sensor on the jeep already?
You said you have to everse the wires at the connection? Why is that? Due the aux switches youre using? (Mopar?) or some other reason?I just wired it to one of my AUX switches. I only run it when off road in 4Lo.
The fan is likely designed to spin to where air would be bowing away from the pump as so reversing polarity would make it spin the other way.You said you have to everse the wires at the connection? Why is that? Due the aux switches youre using? (Mopar?) or some other reason?
Do you have any more pics of where/how you mounted it?
I reversed the wires to make the fan a pusher. At the time I could only find the fan in a puller model. Just mount it in front of the pump attached to the frame of the jeep.You said you have to everse the wires at the connection? Why is that? Due the aux switches youre using? (Mopar?) or some other reason?
That is what you need@Sportacus looks like this is the pusher fan
Amazon.com: Spal 30103009 4" Paddle Blade Pusher Fan : Automotive
not sure where to post this...
heading to the Rubicon at the end of July for the Jeep Jamboree. i have been modifying my jeep like crazy to prepare for it: 392 axles, MC 3.5" lift, RCV axles, new 37" tires, skid plates, driveshafts, etc...
im about to swap my aluminum steering box for the steel one and installing Steer Smarts brace while at it.
now its been mentioned to look at the APEX steering boost kit. (PSC etc are not in the picture financially any time soon). This Apex kit is affordable at this moment. not that i want to spend another $400 right now....
what im also running low on (besides cash) is time. im down to a little over 3 weeks. this install looks pretty involved. i still have more stuff to take care of, little things here and there. by the time i get the kit, take the jeep apart, install it, and get it back together, could be pushing it. i dont want to be rushing it back together before its time to start packing to go on the trip.
my question is, would this make a considerable difference for my jeep on the Rubicon trail? i know its going to be hours of crawling, and im on 37s.
and maybe im overthinking the install. i have to look more into doing it without removing the grill/bumper. that's the worst part of it all.
obviously many people have made it through without any kind of steering boost of any sorts, including on 37s. does it suck? would it make it much better? meh?
I'm guessing a handheld GMRS in addition to an installed Ham radio would be acceptable?
"Hey guys, wanna listen to me pee" - everyone's dumbass friendfor nature breaks
Did you retire out of the high altitude helicopter unit there at Eagle a/p.That is what you need
Yes, retired from HAATS in 2022Did you retire out of the high altitude helicopter unit there at Eagle a/p.
My old stomping grounds.Yes, retired from HAATS in 2022
