Power tap in cabin
AC77
AC Abegian
Los Angeles
Autobody , singer-songwriter
Hi there. Does anyone have or can point me to a link where I can see a ACC + power source on the driver side footwell ? Can be on a harness. Obd port. Anywhere around the driver side. Thanks
AndySpill
Andy
Pittsburgh
2018 JL Sahara
AC:
I think your looking for an accessory power source when your say ACC: one that's only energized when the vehicle start button is not in the OFF state.
If I'm wrong, and you can live with a power source that's always energized (i.e. a battery source) then pin 16 on the ODB port is a good place.
https://www.flexihub.com/oobd2-pinout/
If you need accessory only power, consider one of these:
https://www.amazon.com/gp/product/B0886DNNSP/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
They are very easy to install, tap the 12V accessory plug in the dash on the inside of the panel, not taking up the port, and can have you easily extend your wires into the driver's side footwell.
AC77
AC77
AC Abegian
Los Angeles
AC:
hi Andy. ACC I mean accessory and yes. Thank you. The second option is what I will need. I will order this. Wow. Learned something new today 👍👍🙏🏻
