Plastic Rivets and tool
Jondrew
Bob
Central Fl
2018 Rubicon
i did a headlight install over the weekend and it probably would have been easiest to just pull the front fenders off. But I did not have the appropriate rivets in my bag of fasteners. Just the standard reusable plastic fasteners.
Are these 1/4 plastic rivets? I see a bag of 25 on amazon for $7. What about the installation tool? They had one on there for $23.
https://www.amazon.com/Expansion-Ri...NPBB029PQ9T&psc=1&refRID=9BCGHJQD5NPBB029PQ9T
Ormond Beach, Florida
Retired at 55 ..
@Jondrew
Those little rivets are pricey from what I have heard. $5.00+- each.
Best be would have been to just pull the flair itself.
The white plastic clips that hold the flair on are very stout.
You can pull the flair and pop it right back on using the same clips.
Here is a pic of the clip used for the flair. They cost about $.65 each.
Jeep Wrangler JL Plastic Rivets and tool jl-wrangler-wheel-flare-clip-2
jawest12
Aaron
WV
jeepinwv.com
2020 JLU Rubicon, 2018 JLU Sahara
Those rivets work great. I've used them when I installed rock lights. Just make sure you get the poly rivet tool. It's not expensive and does its job perfectly.
LS7
Salt Lake City
'66 CJ5, ‘18 JLUR
@Jondrew
When my Jeep was delivered, one of the flare clips shown in your photo was not fully seated. I could not seat it because the fender liner prevented me from putting pressure where I needed to, so I took it to the dealer. They removed the fender liner, seated the flare clip and re-riveted the liner. Will you please explain how I could have seated the clip without removing the liner? Thanks.
Retired at 55 ..
@LS7
Funny, your dealer did not have to do as they did...
I helped a friend pull the flares on his JL. Really was not that big a deal.
Funny, afterwards, I found a video on YouTube that showed the process to remove. I just hunted down the video.... here you are:
LS7
Salt Lake City
'66 CJ5, ‘18 JLUR
@LS7
Forgot to mention... If you need to replace the $.65+- white clip, they are readily had. Here is one place to get:
https://www.justforjeeps.com/68395634aa.html
Thanks. Unfortunately, the video only shows how to take the flare off, not how to put it back on. My problem was that I could not press the clip back in without having access to put pressure directly behind it. Pushing on the outer edge of the flare would not do it.
Retired at 55 ..
@LS7
Not sure what to tell you.. My friend and I removed the flares. He reinstalled the next day.
He said they easily pushed right back on easily. I distinctly, remembered asking him.
I might add he is not good at wrenching , so if he said it pushed back on easily, I assume it did.. otherwise he would have had me back there helping him.
By the way, he is 76 yo and blind as a bat... ho, ho, ho...
LS7
Salt Lake City
'66 CJ5, ‘18 JLUR
@LS7
He said they easily pushed right back on easily. I distinctly, remembered asking him. I
You know how to hurt a guy. I’m not quite that old and occasionally I can still see the light.
melendez69
Marc
Waxhaw NC
...huh?
Alanscott1
Central NJ
2024 2dr Sport 6spd
A&P Mechanic
I ordered these, worked fine: Rexka 50pcs Fender Flare Plastic Rivet 1/4 Hole for Chrysler 6506007AA 07-18 Jeep Wrangler, Wrangler Unlimited JK https://www.amazon.com/dp/B07D6JXC4Q/ref=cm_sw_r_cp_api_i_0c1xCbK9RXTAP
devicemanager
West TX
'20 JLUR
