GPWER
- Mar 21, 2020
- Recall USA
- 2019 2DR JL RUBICON
I know many have complained about the pinging and noisy valve train. I began using different octane gasoline from 87, 93, 94, 98 and 100 octane with no significant change. I did a oil change this time using 4 qts of 5w30 and 1 qt 0w20 all pre detonation and valve train noises were no longer there. I drive a manual 6 speed It typically happened going uphill when shifting or low rpm high load. I strongly recommend following mfgs recommendations. The reason I tried this, jeep did it with the 2.0 turbo motor for the pre detonation and valve train noise TSB. This is for information only I do not recomend going outside of MFGs recomendations as it calls for 0w20.
