Phaser issue
Milerman
Flotida
2018 grand cherokee 5.7 trailhawk
I have replace piston and rods. Cams and lifters with rockers. Engine runs but has 30 pounds compression on right bank and 130 on left bank. Any ideas on why?
Milerman
Flotida
I have triple checked timing marks for all chains as well
StonerSR25
Tucson AZ
2024 Jeep Rubicon X
Not familiar with your motor, but, are the rocker arms adjustable, or are there shims under the cam lobes? Try a compression leak down test to determine where your compression is escaping.
Milerman
Flotida
Motor has hydraulic adjusting lifters. Leak down showed nothing all 6 are the same it appears to be valve timing issue
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
You set up the chains wrong?
exactly which marks did you align on the right bank? The arrows will fuck you.
