Sean L
- Sean
- Mar 9, 2018
- North Carolina
- 2018 JLU, 2017 Honda Accord, 2014 Yamaha XVS 1300
- Occupation
- Retired Marine, Construction Estimator
- Vehicle Showcase
- 2
With that BSG on the 3.6, you would still have an additional 90 Lb-Ft of torque in the low end even if you disable the ESS function.I’m thinking that BSG etorque is valuable from a performance stand point with the 2.0T because the turbo won’t provide any power until it spools up at maybe 1500 rpm. So, etorque helps the 2.0 get off the line and helps in crawling.
The V6 doen’t really need etorque for those purposes especially if you turn off ESS with a tazer.
I think I’d rather have the V6 without the BSG in order to avoid the add’l complexity and weight.
