Passive Entry not working
INCRHULK
Lance
Canada
litwphoto.com
2019 Wrangler Unlimited Sahara (retired), 2021 Gladiator Rubicon Diesel
Program Manager, Information Technology
I've recently picked up a gremlin with my passive entry not working. Touching the front doors or tailgate no longer unlocks the Jeep. Using the button on the fob does. Once in the Jeep, pressing the START button results in "Key Fob not Detected". Holding the fob to the button works, as does holding the fob against the top of either B-Pillar. (That is where two of the antennas for the RKE exist.)
I pulled the HVAC and PDU/window switch cluster and the antenna and leads (where I can see them) seem fine. I may have had a critter take up residence in the Jeep for a week or two and chewed a lead deeper in the dash. Does anyone know where the control module is mounted? I'm loath to deconstruct the entire dash in winter weather. I've started to have the weird "replace the green CAN BUS" gremlins. Would the wiring for the antenna run through this bus?
Error codes pulled from the Taser:
PTS B1297-25 (dirty parking sensor)
RHF B1A10-00 U1A74-13 (I can't find anything about the second code)
BCM U113B-00 P113E-00 (The first might be the orange wire on my AUX switch bank; I need to look at it; the second is an O2 sensor?).
Bobby Hank
Robert
Gulf Breeze Florida
2024 JL Wrangler Rubicon X 2D
Educator
Could it be a key fob battery? Try everything with the spare key.
Dyolfknip74
Ottawa, Ontario, Canada
2021 JLU Rubicon
Other fob do the same? This sounds like a fob battery issue.
INCRHULK
INCRHULK
Lance
Canada
litwphoto.com
INCRHULK
INCRHULK
Lance
Canada
litwphoto.com
Dyolfknip74
2021 JLU Rubicon
Hmmm. You could pull the trim piece off where your push button and climate control is. The RF module is under there and the push start module as well. Maybe reseat wiring?
INCRHULK
INCRHULK
Lance
Canada
litwphoto.com
Yup, did that this morning when I checked the antenna module and its connector. I’ve ordered up a replacement green CAN BUS connector and will see if that’s the issue.
Dyolfknip74
2021 JLU Rubicon
Well shit. What an odd one.
No other weird electrical stuff going on? Aux battery good? Lol.
INCRHULK
INCRHULK
Lance
Canada
litwphoto.com
Yup. Replaced both beginning of the year.
