Passenger door alignment issue
spreadhead14
Paul
San Diego, Ca
2018 JLU Wrangler Rubicon
I have terrible road noise coming from the passenger door due to an alignment issue. Any suggestions? Anyone have this issue?
Jeep Wrangler JL Passenger door alignment issue tempImageXZLFq6
Reinen
2021 Jeep Wrangler JL Rubicon
Loosen the door hinge to door bolts (but do not remove), align the door giving an extra MM on the rear side for sag, tighten the hinge bolts to 21 ft/lbs. I had to do that on my driver door once.
spreadhead14
spreadhead14
Paul
San Diego, Ca
Thanks for the advise! Which ones are those?
Windshieldfarmer
Randy
Wichita, Ks
2015 JKU, 2020 JlU on order
Have the dealer adjust if in warranty. You can chalk the seals to determine where the gap is….
Pinion
Rob
Hull, MA
1971 FJ40, 22 Rubicon Unlimited
Project Manager
Sometimes the weather stripping pops off the door, but looks like it's still connected. Check to make sure it's in the groove all the way around.
Dyolfknip74
Ottawa, Ontario, Canada
2021 JLU Rubicon
I cant see a misalignment but unless it's crooked on the hinges, the majority of adjustments are done on the hinge part that is attached to the body of the jeep. Not the door. I'd start there.
spreadhead14
spreadhead14
Paul
San Diego, Ca
I replaced the bottom door hinges with brand new ones.
