Parking brake assembly
dagrizz
dylan
Tampa, FL
2018 jeep jl wrangler
Hello all.
I bought a rubicon rear axle used with no shafts or brakes (for my JLU sport). I bought new parking brake assembly item number 68249593AA but would not fit even though fitment says 2018-2021 wranglers sport or rubicon…
Does anyone know if it’s 68299457AA? Says specifically for rubicon models only..
any help would be appreciated!
Willys41
Larry
Pleasanton Ca.
2020 Jeep Willys
I did the same thing
Bought a used rear Dana 44 e-locker to replace my 44 on my 2020 Willys
It also has no backing plates or axles
I found a set of used Rubicon axles put did not realize they have a larger ABS tone ring until I went to put it in
I could see that the ABS tone rings where different
On the Rubicon E-locker the tone ring has a larger OD and the ABS sensor will hit the tone ring
I was assuming also that the 68299457AA backing plate was the answer put they are back ordered
Can you tell me why the 68299457AA did not fit and did you find the solution
Thanks Larry
Toxiclows
Christopher
2020 Willy’s jl
Did you find an answer to this? My 2020 Willy’s got a rubicon bare axle as well. Found shafts and put it in tonight and realized I did not plan on this. Backing plates are different. Did your Willy’s caliper bracket and caliper bolt up and brake rotor. Or did you have to replace all of this stuff as well?
Toxiclows
Christopher
2020 Willy’s jl
Ok just looked up in Dealer Connect for mine and used the vin of the rubicon that I got my diff out of. And it is saying. That 68299457AA is the correct part
Shellbird01
Bob
Ontario Canada
2018 Wrangler JL Shara Unlimited
Hey Thanks for finishing a post with a solution even tho you’re not the OP.
