Creaky parking brake
Turaven
'23 Wrangler Sport 4-door 6MT
I've noticed for a while now a creaking noise from the rear of my Jeep when it's parked and gets wiggled, meaning stepping in or out primarily. I presumed it was a spring on the rear suspension or something and I can't hear it while moving.
I've realized now that the culprit is the parking brake. If I actuate the parking brake while holding the release button (so there's no ratcheting noise) I can hear a pretty loud stretchy/creaky noise. If I lie under the Jeep and wiggle it the sound is pretty clearly coming from the brake rotor area. Acuating the parking brake in the cabin has a loud and nearby sound, so I'm guessing it's the cable itself mostly.
If I sit on the foot brake and shake the Jeep I usually hear nothing or just the tiniest, faintest noise from the rear. It's dead silent if I shake it with no brakes engaged. I don't notice the parking brake sticking or performing abnormally at all. It holds the Jeep even on a decent incline.
Do you guys think this is anything to worry about? I've been planning on getting it looked at next time I get some service done, probably oil change in a couple months unless the clutch recall becomes available before then.
Tethmes
Dylan
Michigan
2022 JLWS, 2023 KLR650
Management
Last I heard on recall being available was September, but who knows if it's accurate. As far as the parking brake, service schedule recommends that it be adjusted every 2 years or 20k miles. So if you're past that it wouldn't be a bad idea to get it looked at. Otherwise, parking brakes do creak at times, usually if you are parking on an incline and don't have quite enough pressure on it.
Shellbird01
Bob
Ontario Canada
2018 Wrangler JL Shara Unlimited
I thought the same but it turned out to be the sway bar link bushings and track bar bushings.
