Paramount Inner Liners
XX4XEXX
XX4XEXX
JD
Ca
2021 Rubicon
Mechanical Engineer
Honestly for plastic (and they are about 2x thicker then OEM if not more the form and fitment are awesome. Just carry a bag of those rivets in the glove box and done. They should work with all aftermarket fenders I believe.
That's what I wanted to hear. I'm sold.
XX4XEXX
XX4XEXX
JD
Ca
2021 Rubicon
Mechanical Engineer
SlickRickMotoADV
El Sobrante, CA
2019 Wrangler Unlimited Sahara, 2017 Miata Club RF
It might be due to my Apex endlinks, but does anyone else have an issue with the sway bar bolt hitting the liner. I had this happening on my OEM liner, but the Paramount ones seem even closer to the sway bar end link mount bolt. When the suspension moves up and down, disconnected or not (more noise when disconnected), the bolt scrapes up and down and makes an annoying noise.
I'm either going to have to drill a small hole in the Paramount liner and run a long zip tie around the frame to tuck them back more (might not be enough), and/or trim that area out completely with a dremel.
Jeep Wrangler JL Paramount Inner Liners 306355475_1737163749981146_3178894766972513641_n
XX4XEXX
XX4XEXX
JD
Ca
2021 Rubicon
Mechanical Engineer
Yes my boy has same issue. We used a roto zip and notched them perfectly.
SlickRickMotoADV
El Sobrante, CA
Great. Thanks for that. I just drilled a tiny hole near that area and ran a long zip tie around the frame there. Seems to have minimized the issue. If it doesn't, I just picked up a battery operated rotary tool and will trim that area down. Does your friend happen to be able to send me a pic of the final cuts he made?
I had to remove the inner fenders so many times over the past few days that the hardware completely destroyed itself. Ordered a universal plastic fastener kit off of Amazon, so hopefully I can get them mounted up again today.
XX4XEXX
XX4XEXX
JD
Ca
2021 Rubicon
Mechanical Engineer
Yes I'll send you a Pic. And yes the Amazon kit works great. I have a big bag I carry in my kit for back up.
Bocephus
Virginia
Sam’s Decorative Automotive Button Emporium
Did paramount go out of business?
I’ve been trying to get these…
jax501
'24 JLR
I tried to buy a set also. They were out of stock for a long time and now online stores like Quadratec say they are no longer available.
I don't even see them listed as a product on Paramount's website anymore:
https://paramount-automotive.com/
Bocephus
Virginia
Thanks @jax501 , too bad there aren’t other similar options in market.
Jeepjoy
Jason
SF Bay Area
2024 JL wrangler rubicon
Has anybody heard if these will be available. I messaged paramount with no answer. I'd prefer plastic oem look instead of aluminum.
