Oxygen Sensor malfunction
Iowawink
Iowa
2021 Wrangler Sport JL 2-Door
Has anyone with 2021 or newer JL Wrangler experienced a malfunctioning oxygen sensor? It had a replacement cost of &599? Wondering how common this is and why it is not a recall or free replacement.
melendez69
Marc
Waxhaw NC
2018 3.6 JLR / 2013 991 911 / 2013 E92 M3
...huh?
O2 sensor malfunctions may not be specific to any particular MY... upstream, downstream? Is dealer giving you this information, or did you pull codes?
Quite a few of us (including me... leaking pcv valve) have experienced this for one reason or another... but $600 seems steep.
O2 thread
Heimkehr
Pennsylvania
2021 JLU 2.0T
Yes. I replaced both upstream O2 sensors on my 2.0T to resolve a recurrent P1128 CEL.
I selected the sensor that cost a fair bit less than the other one, hoping to save a few $$ and resolve said CEL. Nope. Only when the second sensor was replaced did the CEL go out and stay off. That's how these things go, sometimes.
I already had the appropriate socket kit on hand, so this was a straightforward and comparatively speedy job in my garage.
The OEM sensor that solved the issue was $115.00. Assuming a $599.00 quote, there's no way in Hades that the associated labor should cost anywhere close to $484.00.
There's a recent thread that discusses O2 sensor failures occurring on the Pentastar. It's been suggested that there's a known overvoltage issue between the PCM and the sensor, where the excess voltage is damaging the sensor's heater. That in turn triggers the related CEL. As the sensor is a sealed assembly, repair isn't possible. Replacement is the only choice.
alphawolff
california
2021 JLU
Recall = safety issue
Failed o2 sensor = emissions issue
Iowawink
Iowa
Iowawink
Iowa
Thank you for that complete answer, much appreciated!
Iowawink
Iowa
O2 thread
Dealer pulled codes, I declined repair in short term Will look at the paperwork more closely.
ajrez
Aaron
Waller, TX
24 JLR MT 3.6L
I replaced one of mine in July (Bank 1 Downstream), paid $60 for it from the dealership and had it installed in 30 min. $600 definitely sounds outrageous.
v-rider
SE Michigan
F150, Toyota Sienna, KTM
If you have any codes that are related to O2 sensor "open heater circuit" you most likely had an overvoltage or overcharging event that cracked the ceramic heater inside the sensor. Stellantis knows that the JL, JT and VR platforms are experiencing this and it seems they haven't determined the root cause yet. This is NOT a sensor quality issue, so replacing the sensors without fixing the root cause will just leave you to replace the sensors (and maybe other components) later on down the road.
