Oil Catch Can Install
Willys41
Larry
Pleasanton Ca.
2020 Jeep Willys
So Willys41 do you have a PN for the new pcv ?
I be leave its 68210345AC.
I measured the oil from the catch can before and after the new pcv valve and there was no difference in the amount of oil it collected.
Willys41
Larry
Pleasanton Ca.
2020 Jeep Willys
If you really have a oil related pre-ignition problem, there is too much blow-by and you have a serious engine health issue. That said, if you need to get more oil vapor out of your PCV output, installing an air-oil separator like the Mann-Hummel ProVent type is going to remove more oil vapor. The difference between a "hot rod" or "racing" catch-can and a production intended air-oil separator is that the latter is that it incorporates a self draining feature, often is much higher volume to expand and condense the vapor, and often has a filter membrane to catch more oil vapor.
The opposing view from members here, of a catch-can on our jeeps, is based on that blown engine thread reference where it's believed the catch-can had accumulated a significant amount of oil from very steep maneuvers, then the contents of the catch-can was ingested in a high rate, and caused a hydraulic lock in the cylinders.
I'm getting ready to install a Teraflex Crankcase Breather check valve system to prevent that type of event. I can see where a catch-can or M-H ProVent type separator could be incorporated in this setup.
If what you are saying ( too much blow-by) Than all the 3.6 have too much blow-by.
Its not just the 3.6 There are other engine manufactures that have an poor PCV system.
Some Ford engines for example.
TSB 09-012-22
https://www.jlwranglerforums.com/fo...r-3-6-for-spark-knock-and-misfire-cel.108824/
roaniecowpony
Retired Engineer
I will probably be switching to that oil too. The last time I took my used oil in for recycling, the guy who dumped it in the tank said that was noticeably the thinnest oil he had seen. 0w-20 oil from my wife’s Subaru.
The viscosity when cold will be misleading as to its operating temperature viscosity. A 0w20 and a 0w40 could have the same apparent viscosity when cold, but be much different at 100C.
Willys41
Larry
Pleasanton Ca.
2020 Jeep Willys
That correct.
I have seen no oil pressure difference between 5w30 and 5w40 put I would think that the higher viscosity when hot can only help the valve train.
roaniecowpony
Retired Engineer
TSB 09-012-22
Larry, I haven't had a pre-ignition issue with my 3.6L. When I had the intake manifolds off for recent work, the ports and backsides of the intake valves looked pretty clean. As with any engine with a PCV system, it will have some oil film in the intake. It only has about 33,000 miles on it.
roaniecowpony
Retired Engineer
That correct.
I wouldn't expect the oil pressure to change except possibly a very slight amount when the oil is hot at idle, when pressure can drop below the relief spring setting. Agree on the higher viscosity for valvetrain.
Willys41
Larry
Pleasanton Ca.
2020 Jeep Willys
I can only state what I have seen on mine and others.
It is a problem. maybe with PCV system or the oil centrifugal oil slinger at the back of the cam where the PCV valve is located.
Dusty Dude
Colorado Springs, CO
1970 Ply Roadrunner, 2010 Challenger SRT
Agreed. My reasoning for changing was for the viscosity when hot. IMHO, xW-20 is too light of an oil. Especially if the engine gets above normal operating temperature for any short period of time.
BEJEEP
AL
Fort Lauderdale
2023 Jeep Beach High Tide
If you saw the amount of oil that dumps out of a 3.6 intake everyday you might reconsider lol
Yup, what he said^^^^^ Almost filled the canister with 3,500 miles.…….
roaniecowpony
Retired Engineer
I currently have a fill of 5w30 M1 EP in the sump after multiple flushes from coolant contamination by way of the oil cooler seals. I'll put in 0w40 if my last UOA comes back good.
Heimkehr
Pennsylvania
2021 JLU 2.0T
If your dealership is kicking your warranty due to a oil catch can then you have a shitty dealership point blank.
Lousy CDJR dealerships aren't unknown to this community. Our wariness regarding engine modifications is earned.
alphawolff
california
2021 JLU
I also realized you just recommended me to change my PCV valve on a 2024 with 300 miles on the engine lol
There's no shot a 2024 is dumping oil into the intake like that, surely?
I was talking about the others who mentioned it
PotterJLUR
PotterJLUR
Kansas
www.youtube.com
2024 392 Rubicon, RAM TRX, Camaro ZL1 1LE
I installed the catch can the first day I drove the jeep home and only have 300 miles on the odometer and am already collecting oil in the catch can.
alphawolff
california
2021 JLU
That is insane and not normal. Then again, I'm not surprised with how the 3.6l build quality has been these last few years. Pacificas & WLs are blowing hadgaskets right at 50-60k miles like clockwork. Fortunately haven't seen many wranglers with that issue
