Offset (wheel/tire combo)?
dr.jeep1695
CA.
Wrangler 2022 Willy's
2022 JL 2 door Willys w/ 2" Mopar lift
New Tires: 315 70 17
New Wheels: 17" x 8 or 17" x 8.5, 17" x 9??
Not sure of offset of how the tires will look?... how much will the tires above approximately stick out past existing factory fender?
I know the tires themselves are wider than the original 255 ones which are tucked in vs.(2.4" wider with the 315 tires)
Trying to pick out different wheels since originals too small....
-12mm
0mm
+12mm
Looking for maybe an inch or so past...not too much?
Thanks to all those whom are so helpful and knowledgeable. Any pictures helpful with the brand or wheels you have...
SWVA JLUR
Virginia
JLUR Wrangler
Those tires on 17x9 wheels with -12 offset will stick out roughly 2.8 inches.
Jeep Wrangler JL Offset (wheel/tire combo)? IMG_6970
Whiskey 13
Northwest Florida
2020 JLUR White Rubicon, Warn 10000 Lb. Winch Syn. Rope, 35X12.5 KO2
Stock rims on a Rubicon were 17 X 7.5 with if I remember correctly a +41 offset. AEV, Fuel, KMC and several other wheel manufacturers now offer more positive offset wheels. I have KMC Mesa 17 X 9 with +25 and the 35 X 12.5 KO2 tires are only out about an inch. I have no issues with clearance.
Old Dogger
Cave Creek Arizona
17 X 9” wide Rim, with 4.5 back spacing, is a very popular wheel used.
The Fixer
North Jersey
2018 Mojito! JLS, 2018 Firecracker JLUSS
Teacher
These are 17x9s, (5.25" backspacing, 6mm offset according to Quadratec) with 315's. I believe your '22 Willys has the same axles and flares as my Sport.
Jeep Wrangler JL Offset (wheel/tire combo)? IMG_7697.JPG
Jeep Wrangler JL Offset (wheel/tire combo)? IMG_7699.JPG
ijp4fun
Northern Ca
05LJ 2015 Cherokee 2024 JLURX
35 x 12.50, Ion 17x9, 5" backspacing 0 offset.
Jeep Wrangler JL Offset (wheel/tire combo)? 20241206_122741
rossneill
Ross
Baton Rouge
Jeep Gladiator 2023 sport
I got 17x9 +12 with 265 wide tires they stick out about a inch if you don’t want them to stick out the more + you go the less they stick out factory is +26 but they might rub if you go to much if you can find them 35x10.5x17 will work with factory wheels
ChoSunJuan
Canada
2004 Nissan Xterra
-12mm
0mm
+12mm
Method Bead Grip 703 is available in 17 x 8.5 with a +25 offset which will poke out 3/4".
My friend has them on her '23 Gladiator Rubicon and they look really good.
