Off road lights kit
kristischr
kristis
Cyprus
jeep wrangler rubicon 2024
Hello fellow jeepers,i am considering buying dual a-pillar mounts on my jeep.I will install Lazerlamps utility 50 (floodlight 5000 lumens per light ) + lazerlights RP spot 8940 (spotlight 8940 lumens per light)per side of the car ,my question is, is it a good combo? Flood + spot. I want to keep it kind if minimal.
And also if i install them next to each other be a good option? Any hood glares? And also i would like to install them myself how easy is to do that?
I do moderate off-roading.
thanks guys
Atomic-Mouse
Northeast
If the lights come with a wire harness it’s usually pretty simple plug and play. If you have factory Jeep AUX switches that makes the process easier and saves running wires through the firewall.
I have flood/spot combos on my JKs A pillar but have always found the hood glare to be a bit annoying. My lights have the amber backlighting and I do use that function a lot while traveling forest roads so I show up better for oncoming traffic.
kristischr
kristis
Cyprus
I have flood/spot combos on my JKs A pillar but have always found the hood glare to be a bit too much. My lights have the amber backlighting and I do use that function a lot while traveling forest roads so I show up better for oncoming traffic.
So the hood glare its a thing i have ti consider..
Thanks mate
70Olds442
Ray
Illinois
2020 Jeep Wrangler Unlimited Rubicon Recon
I'm using the DV8 mounts (link below) with RIGID spots pointing forward and floods angled to the sides. This allows them to cover a wide area and the spots extend out past my OEM LED bright lights. They are fantastic, I love them. They really light things up! I have them wired in to one of my factory AUX switches. I initially had some hood glare but once I got them aligned right, that went away.
Jeep Wrangler JL & Gladiator JT Dual Pod Mounts | DV8 Offroad https://share.google/daCCHGzgqcKuyvrrT
kristischr
kristis
Cyprus
Great to hear that mate,thank you so much
