OEM axle upgrade
Mattgo6
Jacksonville Florida
2021 Wrangler Unlimited
Hello,
I have a 2021 Jeep Wrangler Unlimited Willys. It currently has the M186 conventional differential front axle. I wanted to upgrade to a little more heavy duty axle with a locker. I was told about OEM part number 68585731AA which appears to be a standard width (non-Rubicon wide) front axle that is an M210 with locker and 4.10 gears.
Does anyone know if this axle would bolt in under my Jeep? I know I would have to get a switch and run power to the e-locker since I do not have the controls for it, but otherwise, would this fit?
My VIN is 1C4HJXDN5MW576605.
morrisl29
Morris
Dodge City, KS
2019 Jeep Wrangler Sport Unlimited
I don't know, but here's what Mopar parts catalog says that axle will fit.
If you go to the link below and enter your vehicle it may help answer your question
https://store.mopar.com/oem-parts/mopar-service-front-axle-68585731aa
Service Front Axle - Mopar (68585731AA)
2021-2023 Jeep Wrangler - 68585731aa
2021JeepWrangler80th Anniversary, Freedom, Islander, Rubicon, Sport, Sport S, Unlimited 80th Anniversary, Unlimited Freedom, Unlimited High Altitude, Unlimited Islander, Unlimited Rubicon, Unlimited Rubicon 392, Unlimited Sahara, Unlimited Sahara Altitude, Unlimited Sport, Unlimited Sport Altitude, Unlimited Sport S, Unlimited Willys, Unlimited Willys Sport, Willys, Willys Sport2.0L L4 - Gas, 3.0L V6 - Diesel, 3.6L V6 - Electric/Gas, 3.6L V6 - Gas, 6.4L V8 - Gas
Jeeps2Little
Lost in Utah
2021 Wrangler Sport S Unlimited 8spd
@Mattgo6 It will only work if you regear your existing rear axle to match the 4.10 ratio of the one you want, or buy a complete set of M210/M220 axles in 4.10 ratio. Yours are currently 3.45, font and rear and you can't have mismatched ratios. There are no stock/mopar axles with 3.45 and lockers, front or rear, that I am aware of.
