Odd Clutch Engagement Noise. HELP!
justprentice
Prentice
Edgewater, Florida
www.instagram.com
2021 JLU Willys Sport 3.6L 6-speed
Wilderness Paramedic
I don’t think this is a bearing noise, but maybe y’all have an idea. Upon clutch engagement in 1st gear from a stop, I get a new, strange friction point resistance and a noise that I can’t describe other than a "groan" but can document.
Had a new complete ACT kit w/ flywheel put in via a local Jeep specialist and it seemed to have some jutter from the beginning they they dismissed when I took it back to check it out. It still jutters a bit without throttle but 1/4 inch throttle, but now makes this sound and I have no ideas. HELP?
chevymitchell
Shawn
Pueblo West, CO
Avi Engineer
Noise @ 0:04 in video - I don’t think this is a bearing noise, but maybe y’all have an idea. Upon clutch engagement in 1st gear from a stop, I get a new, strange friction point resistance and a noise that I can’t describe but can document as it isn’t intermittent.
Had a new complete ACT kit w/ flywheel put in via a local Jeep specialist months ago and it seemed to have some jutter from the beginning they they dismissed when I took it back to check it out. It still jutters a bit without throttle but 1/4 inch throttle, but now makes this sound and I have no ideas. HELP?
Your clutch needs to be taken back out and inspected immediately. I wouldn't continue to drive it.
justprentice
justprentice
Prentice
Edgewater, Florida
www.instagram.com
justprentice
justprentice
Prentice
Edgewater, Florida
www.instagram.com
I wanted to bump this back up, because the initial judder & noise has seemingly become a "groan" and I want to know what y'all think. I have a short YouTube video for reference.
2021 JLU ACT HD-Perf Clutch "Groan"
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
justprentice
justprentice
Prentice
Edgewater, Florida
www.instagram.com
@Actman I was told you’re on here by your team when I called today. Any ideas?
fczabala
FL
JLUR; X5
following this... my ACT clutch also developed this "grinding" or "rattling" noise about 2k-3k miles after install
however, I'm not sure if it's the clutch or something else that got loose and needs to be torqued like a bolt on a driveshaft (I'll admit I've been procrastinating to have it inspected but
definitely triggered my ocd) so tomorrow I'll see if I can have it put on a lift and have it checked out
the noise happens about 99% of the time going forward from a complete stop, there's been once or twice that it hasn't made the noise and I also haven't noticed it as much while on reverse
also I was on 4h once and when switched back to 2H it didn't make the noise like the first 2 times
I'll try to record it tomorrow to compare but what do you think @chevymitchell ? I'm suspecting it has something to do with the yoke of the front driveshaft since it was removed during clutch install and I don't remember it being torqued "properly" when reinstalling neither I might have stepped away for a minute while this was happening
I also contacted act customer service, @Actman, and was told that the engineers said since I wasn't hearing it on every shift/gear it couldn't be the clutch, I asked again if 1st and reverse being under the most load mattered and again was told if it was the clutch I would hear it every time it engaged on any gear
Actman
Rock Sponsor (Level 1)
Dirk
Lancaster, CA
www.advancedclutch.com
2015 Jeep Wrangler JKUR, 2003 Jeep Wrangler
President and head cheerleader at ACT
Eric forwarded the video you sent and I looked it over. I have a few questions so will send you a PM to discuss. There is no reason to stop driving the vehicle as chevymitchell suggests.
cander58
Minnesota
18 JLU Sahara
This sounds similar to a sound mine makes on occasion, except I have the OEM clutch. Does a little judder and sounds clunky. Not everytime I take off from a stop though.
fczabala
FL
JLUR; X5
Hey Dirk, mine is also doing the same on 1st, do you have an email I could send you a video?
fczabala
FL
JLUR; X5
@22Mojave
Couldn't see the videos you posted on the other thread, is it similar to the sound on the video from the OP of this thread?
22Mojave
Kevin
Michigan
2022 Jeep gladiator mojave
@22Mojave
The noise 100% the same thing! I’m so glad I found you on here.
22Mojave
Kevin
Michigan
Hey, I 100% have the same issue!! Any updates?
