forest
- Justin
- Dec 16, 2023
- Buffalo NY
- 2021 JLUR
Hey everyone, I just bought a 2021 JLUR with ~36k on it. When I first test drove it and for the first couple of days I had it I don't recall this happening. Let's say i'm in 3rd gear doing about 30 mph and a red light is coming up. So let off the gas get on the brake and at around 15mph I push in on the clutch and shift into neutral. Now as soon I push in on the clutch my RPMs start to drop with no issue and keep dropping while on the clutch. After i shift into neutral and let off the clutch my RPMs go back up to about 1500 or so. As the vehicle continues to slow the RPMs slow with it until I come to a complete stop at which point the RPMs are still a little hight at about 1.1k and after two seconds or so the RMPs will drop down to ~800 which is what I consider normal idle. It does this even after the engine is up to operating temp and like i said before I swear it didn't so this before. There are no odd sounds or feel in the clutch or smells. Wondering if this is a normal thing that jeeps do? My old Subaru Sti could be shifted into neutral at 90mph and the rpms went ~700 and that is the behavior I would expect out of any manual. Also it's only done this the last two trips i've taken, i'm going to drop it off for a clutch estimate in a couple hours and i wrote a note to the shop to check it as well. Clutch doesn't feel broken but i plan on replacing it with an ACT regardless (my Sti had an ACT clutch and it was great). Thanks for any input here.
