Help identifying engine noise
Rrr8400
Kevin
Maryland
2021 Rubicon
I have a 2021 JL Rubicon with almost 6K miles on it. Just the past week or so it the engine started making a different sound when accelerating, usually heard between 3-4K rpms. It goes away when I shift and then comes back as the engine speed gets back between 3-4K rpms. It is intermittent and hard to describe, kind of like a rattle. It sounds like its coming from the driver side, in the area of the engine near the pedals.
I haven't changed what kind of gas I use, and its happened on more than one tank of gas. It happens both when the engine is hot and cold. Thanks for any advice.
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
Man that just sounds like exhaust.
Rrr8400
Kevin
Maryland
2021 Rubicon
Thanks and agreed - something to worry about? Went prob 5500 miles before it started. Also what would cause an intermittent change in exhaust sound. If there was a hole or something wouldn't it be always there?
mwilk012
Oklahoma
Service
I’d absolutely worry about it. It isn’t a normal sound.
And by worry, I mean it’s annoying and the dealer should fix it. Not to actually worry.
mwilk012
Oklahoma
Service
Can you record it again with your dash displaying oil pressure?
Rrr8400
Kevin
Maryland
2021 Rubicon
I will try this afternoon. Hopefully it will be one of those days when the noise is present
Rrr8400
Kevin
Maryland
2021 Rubicon
Here's the noise with oil pressure in the display
mwilk012
Oklahoma
Service
Hmmm that rise in oil pressure seems slow.
mwilk012
Oklahoma
Service
BullMoose1776
Bull
South Texas
Project Manager
It's not fuel knock. I read somewhere else it's lifters and camshaft. If not under warranty it's about a $1500 fix, iirc.
BullMoose1776
Bull
South Texas
Project Manager
Mine sounds like a loose heat shield, until you have someone else rev the motor, and you get in there, then you can hear it's INSIDE the motor. I tried better fuel, but I heard it last night and realized it's still happening.
mwilk012
Oklahoma
Service
It’s more than that on JL, unless they only do a single head. Cam and lifter noise is more consistent than this, usually.
BullMoose1776
Bull
South Texas
Project Manager
Sure. All I know is, I don't know, so I'm taking it in and I'll get it fixed.
I'm not swearing off jeeps forever, or buying a bronco. It's just a mechanical matter that will get sorted out. Hopefully covered by warranty.
