Noobie Wheel Size Question
jeme
TBD
I am new at this so sorry if this is an obvious question
So I purchased a 2023 Sahara to arrive soon. It is in my profile pic.
Sarah comes standard with 255/70/18 tires on 18 inch wheels. (Obviously)
I want to upgrade to these Mopar rims - these are 17 inch 8.5 inch wide wheels.
So comparing tire size it looks like the narrowest fit would be a 285/70/17. My question is will these tires and wheels fit on my jeep without rubbing etc.
Can anyone help me out here? Some pics below for reference.
Thanks in advance for the help!
Jeep Wrangler JL Noobie Wheel Size Question 4519C977-7113-4F69-82CC-F63B6DEBB4EC
Jeep Wrangler JL Noobie Wheel Size Question 36D02648-CF90-4AA5-BF84-5B286E854085
Jeep Wrangler JL Noobie Wheel Size Question 1C00E5E3-652F-48D2-9F46-394B4AEC0ACC
jeme
jeme
TBD
I guess another question is will this tire fit on my spare tire carrier and will it need to be enforced? Thanks!
Reinen
2021 Jeep Wrangler JL Rubicon
If you use this calculator it will overlay your old and new wheels/tire combo and tell you exactly how much larger the new tire is. https://tiresize.com/wheel-offset-calculator/
Just measure it yourself from the old tire and make sure you have enough room, especially with the front wheels turned as much as they can. You can do the same with the spare.
The spare tire carrier from the factory is designed to hold up to a 50lb tire. Above that you should consider tailgate reinforcement.
Dyolfknip74
Ottawa, Ontario, Canada
2021 JLU Rubicon
Yes, it will fit fine. It's a 33" tire on Mopar wheels. No issues. Maybe very slight rubbing at full flex but you'll have to check. Around town? Zero issues.
The stock tailgate will be fine as well. It's rated up to 85 lbs, not 50lbs like stated above. I ran 106lbs on it for 6-8 months with nonisusesz you'll be fine.
Chocolate Thunder
Jeremy
I have these wheels. They fit on the spare tire carrier without any issues. They’ll fit your stock Jeep without any rubbing or spacers required. A 275/70/17 tire will be very close to the same diameter as the stock Sahara wheels, slightly wider.
kah.mun.rah
Merenkahre Jr.
Duat
So comparing tire size it looks like the narrowest fit would be a 285/70/18. My question is will these tires and wheels fit on my jeep without rubbing etc.
I know you meant 285/70/17 and not 285/70/18 in your comment above based on your description of your new wheel diameter and the chart you provided but just wanted to point it out before you order R18 tires for 17" wheels.
jeme
jeme
TBD
WIll a 275/70/17 fit on a RIM that is 8.5 inches wide? Really appreciate all the help from everyone!!!
Jeep Wrangler JL Noobie Wheel Size Question 5551AB2E-F7A7-4CE9-A7BD-0B21245426E6
jeme
jeme
TBD
Thanks so much, I have corrected that - you understood perfectly.
Chocolate Thunder
Jeremy
Yes. It’s about as wide as you’d want to go in 275 tires, 9” might be a bit too wide.
jeme
jeme
TBD
@jeme, yes you can safely mount a 275/70R-17 tire on a wheel that is 8.5 inches wide.
Thank you Discount Tire. You all are who I use locally here is Florida. You guy do an incredible job and I will be ordering my K02’s from you soon!
Discount Tire
Arizona, USA
discountti.re
All Things JEEP
Tire & Wheel Specialists
Thank you for your kind words, I'm glad to hear your local store does a good job of taking care of you.
If we can help in any way please send us a PM.
William16
William
Riverside California
2022 Jeep Wrangler JL
Will a 17" 8.5 rim with no offset fit on a stock 2022 jeep jl and what is biggest tire that I canput without a lift?
