New LCA versus Front Alignment
18BlackJLRU
YUL
2026 Willys
I will be replacing my 2024 4XE Rubicon Lower Control Arms with new 68322798AA (same as in the Mopar 2" Lift Kit).
Since it will only change my caster, do I really need to have a front alignment have the install ?
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
No, you don’t have to.
Zandcwhite
Zach
Patterson, ca
2019 jlur
The arms you're installing aren't adjustable, so the shop can't do any aligning. They can check your alignment and/or give you the numbers but caster will be what it is. Camber also isn't adjustable. The only thing they could change is the toe, but you aren't touching the tie rod so there's no reason it would need adjusted.
Jeep Wick
Wick
America
2022 High Tide XR
Mechanic
IIRC, you won't need an alignment but you will need to re-center your steering wheel by adjusting the drag link.
18BlackJLRU
18BlackJLRU
YUL
2026 Willys
When I changed my LCA (with the 68322798AA) on my 2018 Rubicon, I had to do an alignment... But I still had to recenter my steering wheel myself !
18BlackJLRU
18BlackJLRU
YUL
2026 Willys
I got my LCA replaced today.
My steering wheel moved a tiny bit to the left, so little off that I might just keep it like that. Does it make sense that it only shifted my steering wheel a bit to the left ?
As with my 2018 back then, the LCA were about 1/4 inch longer than the stock ones !
GATORB8
CLT NC
Yes, it should just be a slight adjustment to the drag link.
LukeDagny
Central PA
2021 JLUR
I agree. When I installed my lift, the steering wheel was no longer centered. It was close. On my test drive, I got some type of warning light. After recentering the wheel, the light went away. IIRC, the warning light was caused by the lane departure system.
