digger2
- Tony
- Dec 12, 2025
- Prescott Az
- 2021 Jl Rubicon
Long term, it's probable the regulations will change agan before the decade is out.The part of me that works at a heavy duty truck dealer group, there goes a cash cow for our business while also being a major headache with DEF sensors constantly on backorder.
The part of me outside of work that thinks the EPA regulations are getting too stringent too soon, this is great.
I do agree that immediate crippling of vehicles on a failure is beyond dangerous. It's not unlike using a howitzer to swat a fly. It's completely out of line with just about every other emissions failure. It should just set a code and turn on a check engine light.
The mandate from the feds is for manufacturers to have a software flash for current vehicles, so even if the rules change back it will be dependent on owners to revisit the dealer for a reversal. Good luck with that.Long term, it's probable the regulations will change agan before the decade is out.
I do agree that immediate crippling of vehicles on a failure is beyond dangerous. It's not unlike using a howitzer to swat a fly. It's completely out of line with just about every other emissions failure. It should just set a code and turn on a check engine light. Maybe, at most, not let you restart after a couple of times.
Guess it was just a bunch of empty promises after all.
Yea I sit here reading this stuff thinking "did nobody grow up back in the days when every other truck or bus had a screaming jimmy barfing out black smoke every time it took off from a red light?""Here's an engine that is so environmentally unfriendly we need 20k in emissions equipment to reasonably allow it on the road. Also, the equipment breaks all the time."
Those things were noisy and stinky and polluted the air like crazy. Nothing like getting crop dusted by the city bus.
Why on EARTH would anyone want to go back to that?
Diesels should be regulated to working vehicles over a certain tonnage. Putting them in generic daily vehicles is a massive misappropriation of design function.Yea I sit here reading this stuff thinking "did nobody grow up back in the days when every other truck or bus had a screaming jimmy barfing out black smoke every time it took off from a red light?"
The amount of people that buy the biggest truck they can afford, then never use it for anything remotely close to its intended purpose, is too damn high!
Then again, turning a literal brick on wheels into a plugin hybrid to be more "economic/green" was also a questionable decision.
