Need Mechanic's help!! Start Issue
Muskoka Minute
Bart
Muskoka Canada
2019 JL Rubicon
I have a 2019 2 door Rubicon.
First thing in the morning the only way to start it is with the remote start. (Button wont work)
After it is started the button will work just fine until it sits for approx 8hr then you have to use the remote start again. After wards the button works just fine.
I. also get a note on the dash saying the right rear signal is out. (only happens for a second then goes out)
I also noticed when its warming up (spread by the remote start) the right rear light kind of flickers.
Dealer said it needed a power distribution center (PDC). Just replaced it and having the same issues.
Suggestions .
garyji
Gary
Western NC
2017 JK Sahara, 2021 JLU Willys
Fix the lights first. 17 months if you didn't go high end on the batteries, could be the issue.
G.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Could be BCM related.
I'd pull codes with a really good code reader (dealer level). Did they list the codes it was throwing when they replaced the PDC?
