- Mike
- May 2, 2018
- Jersey Shore
- '21 2dr Bronco Badlands, 2.3t Manual
- Banned
Figure someone here can figure out the stuff I can't.
Goal is to get a new PC by my birthday/Xmas (2 weeks apart), as my Alienware's graphic card is outdated (According to WoW), and it's running out of memory (500gb ssd), though the 16gb Ram is solid.
Here's what I tend to build: https://www.cyberpowerpc.com/system/Gamer-Infinity-XLC (http://www.cyberpowerpc.com/saved/1LMAAT)
What I wanna do though is be able to play more games, more classics like FO3, VTMB, and other games, but have it run seemlessly and without hiccups (NV is it's own story, as you know no amount of mods can fix it's buggy nature), so with all that said, hows the build look, what can I add or subtract to things without compromise (Definitely want the max performance and storage)
Thanks for taking a look and customizing the build a head of time,
Rogue
- *BASE_PRICE: [+2435]
- CABLE: None
- CARE1: Ultra Enhanced Packaging Solution - Protect Your Dream System During Transit [+19]
- CARE2: Cooler Master Mastergel Maker CPU-Thermal Compound Optimized for Thermal Dissipation [+10]
- CAS: Syber XL Series E-ATX Full-Tower Gaming Case w/ USB 3.0, 7 Color RGB & Full Side Tempered Window Panel [+13]
- CASUPGRADE: CORSAIR Lighting Node PRO individually addressable RGB lighting with software control Kit [+49]
- CC: None
- CD: None
- COOLANT: None
- CPU: Intel® Core™ Processor i9-9900K 3.60GHZ 16MB Intel Smart Cache LGA1151
- CS_FAN: 6X 120mm Enermax T.B RGB Twister Bearing PWM Case Fans 500-1500 RPM w/ Remote Controller [+75]
- ENGRAVING: Custom Picture (we will contact you for picture submission detail after processing your order) [+29]
- EVGA_POWER: None
- FA_HDD: None
- FAN: Thermaltake Water 3.0 360mm ARGB Sync Edition high performance CPU waterblock Cooling System w/ Copper Cold Plate [+128]
- HDD: 4TB Samsung 860 EVO Series SATA-III 6 Gb/s SSD - Seq R/W: Up to 550/520 MB/s, Rnd R/W up to 100/90k [+593] (4TB x 2 (4TB Capacity) RAID 1 Performance with Data Security [+760])
- HDD2: 8TB (8TBx1) SATA-III 6.0Gb/s 64MB Cache 7200RPM HDD [+260] (8TB x 2 (8TB Capacity) RAID 1 Data Mirror Security [+260])
- HEADSET: None
- IUSB: Built-in USB 2.0 Ports
- KEYBOARD: CyberPowerPC Multimedia USB Gaming Keyboard
- MEMORY: 32GB (16GBx2) DDR4/3200MHz Dual Channel Memory [+123] (Corsair Vengeance LPX [+18])
- MICROPHONE: None
- MONITOR: None
- MOPAD: None
- MOTHERBOARD: ASRock Z390 Taichi w/ 802.11ac Wi-Fi, ARGB, USB 3.1, 3 PCIe x16, 2 PCIe x1, 6 SATA3, 3 M.2 SATA/PCIe [+121]
- MOUSE: CyberPowerPC Standard 4000 DPI with Weight System Optical Gaming Mouse
- NETWORK: Onboard Gigabit LAN Network
- OS: Windows 10 Home (64-bit Edition)
- OVERCLOCK: Ultimate OC (Ultimate Overclock 30% or more) [+99]
- POWERSUPPLY: 1200 Watts - Rosewill PHOTON Series 1200W 80 PLUS GOLD Certified Full Modular Power Supply [+62]
- PRO_WIRING: Professional Wiring + LIAN LI STRIMER 24 Pins + Dual 8 Pins Addressable RGB Power extension cables + Controller Set [24Pins Motherboard + Dual 8Pins Video Card [+69]
- PROJECTOR: None
- RUSH: Standard processing time: ship within 5 to 10 Business Days
- SERVICE: 3 Years FREE Service Plan (INCLUDES LABOR AND LIFETIME TECHNICAL SUPPORT)
- SLI_BRIDGE: None
- SOUND: HIGH DEFINITION ON-BOARD 7.1 AUDIO
- SPEAKERS: None
- TUNING: None
- USBHD: None
- USBX: NZXT Internal USB Hub + USB Bluetooth Module [+34]
- VIDEO: ASUS Turbo GeForce RTX™ 2080 Ti 11GB GDDR6 (Turing) [VR Ready] [+76] (Single Card)
- VIVE_HEADSET: None
- WARRANTY: PREMIUM WARRANTY: Standard 1 Year Parts WARRANTY + ONE (1) YEAR SHIPPING [+19]
- WNC: None
- WTV: ASRock H2R 2-in-1 N300 Travel Router + AirPlay / DLNA / Miracast HDMI Dongle, EZCAST [+79]
- _PRICE: (+5331)
Rogue
