Need help with cigarette lighter power.
Trojan_Actual
Johnny
Wichita, Kansas
2020 JLU Sahara 2.0T
Retired Military
Hello,
I installed Oracle headlights a while back, and it required me to patch into my cigarette lighter fuse (20A) to utilize the halos. Now I cannot use the cigarette lighter for any accessories. It’s not the accessory because it works fine on the rear port. Do I need to up the fuse or something? The attached picture is the accessory I’m trying to use. Thanks for any help!
Jeep Wrangler JL Need help with cigarette lighter power. image
Left Field
Tim
Western WA
'67 RS-SS Camaro, 2021 JLUR392
The existing fuse size should be ok. I'd be suspect that somehow the 12VDC power to the lighter socket has been somehow interrupted. Did you use one of these or similar to tap in to the fuse?
Jeep Wrangler JL Need help with cigarette lighter power. Screenshot from 2022-12-15 11-23-59
Send a picture if you can -
LF
Hello,
Trojan_Actual
Trojan_Actual
Johnny
Wichita, Kansas
Retired Military
LF
Yup! Exactly that. Was supplied by Oracle in the kit.
gm920
Gary
San Diego County Mountains
2019 Jeep Wrangler JLUR Billet Silver
Aircraft Maintenance Technician (Retired)
You may be able to find an unused fuse position in the PDC and just put the Cig Lighter power back the way it was.
Trojan_Actual
Trojan_Actual
Johnny
Wichita, Kansas
Retired Military
LF
I have the 20A fuse in the “upper” slot. Does that mean the bottom slot requires a 20A in it as well?
Left Field
Tim
Western WA
Yes, one fuse is for the new circuit (Oracle); the other fuse is for the old circuit (lighter). It is also important that the adapter is installed in the correct orientation. If your new lights are working that suggests that it is oriented correctly, so will only need to add a second fuse. Oracle should have provided one?
Trojan_Actual
Trojan_Actual
Johnny
Wichita, Kansas
Retired Military
I don’t recall. I DO remember trying to put the fuse in the lower hole and it wouldn’t go in without me forcing it so I didn’t. At least I know the answer now though. Thank you!
OreoJeep
Mo
Jeep Wrangler
Any help for me? My cigarette lighter was working find for over 3 years whith my LED lights until just recently i plugged in my air compressor and it stopped working. The fuse tap is in spot 52. The fuses are not blown
QUOTE="Left Field, post: 2195068, member: 54882"]
LF
[/QUOTE]
Jeep Wrangler JL Need help with cigarette lighter power. IMG_4025
Jeep Wrangler JL Need help with cigarette lighter power. IMG_4027
Jeep Wrangler JL Need help with cigarette lighter power. IMG_4030
sherpaJL
Keystone State
2019 JLUR Mojito! ~ 2022 JLUR Hydro Blue
sherpaJL
Keystone State
double check your fuse positions, they appear to be flipped, 20A goes in the bottom slot of the tap.
Jeep Wrangler JL Need help with cigarette lighter power. 1735649554224-it
Jeep Wrangler JL Need help with cigarette lighter power. 1735649626421-pn
OreoJeep
Mo
Jeep Wrangler
These are both 20a (i believe). Not sure why they look diff colors. But i will double check to make sure. These on the fuse tap, right?
Jeep Wrangler JL Need help with cigarette lighter power. IMG_4045
sherpaJL
Keystone State
The OEM in that position is a 20A, the fuse provided by Oracle is a 5A (the colors are similar)
side note: I used the 5A OEM spare (circled in red) because the Oracle 5A fuse (provided) is a POS. The spades are oversized and it needs to be forced in.
I did this install 2 days ago.
Jeep Wrangler JL Need help with cigarette lighter power. 1735651027771-g0
OreoJeep
Mo
Jeep Wrangler
Oooh, interesting!! Okay i wil double check.
Mine arent oracle but they are led and it is probably the same issue (the 5a). Its just weird that it was working fine until i plugged in that air compressor.
Ralioth
STL
JLU
I wonder if Oracle is having supply problems. Installed LEDs a few days ago and both fuses fit fine.
sherpaJL
Keystone State
my other issue was the red wire (circled in blue) isn't actually that long.
It's provided at the same length as the grounding lug wire.
I had to splice in a length to avoid crushing it with the fuse box cover like
OreoJeep appears to have done (circled in magenta). I ran mine behind the fuse box at the firewall.
Jeep Wrangler JL Need help with cigarette lighter power. 1735651592753-jg
Jeep Wrangler JL Need help with cigarette lighter power. 1735651911163-vx
@ORACLE Terry
