Mysterious Interior Piece?
LSUjeep
Louisiana
Jeep Gladiator 80th Anniversary Edition and Jeep Wrangler High Altitude
I mean there's enough clips and other stuff in the trim pieces that one screw missing wouldn't be the end of the world. You might want at least glance it over. At least from a completionist standpoint, it's probably ideal to make sure all of the screws are properly secured.
Thanks!
Badunit
VA
1997 TJ, 2023 JT
Looks like this part: 06512735AA
Parts diagram for a JT shows it to be something to do with the sound bar. Says there are 29 of them. I can't find a good photo of one to post here as comparison.
LSUjeep
Louisiana
Definitely looks likes it. Thanks!
wrang_stang
TX
@LSUjeep
I know exactly what that is.
It helps that I've already removed most of my trim, which is what hides these pieces that you found.
If you remove the trim on your "roll" cage, You got all these clips in there that your trim screws screw into. They're not alligator clips, they're something else. I don't have an exact name for them, I do know that if you happen to take one out as circled in red below, you'll never be able to get it back in. :headbang:
Here's the close-up of that one on the driver side door roll bar that I haven't removed yet. The one circled in purple in the photo above is the same one circled in purple below.
The b pillar crossbar that your soundbar mounts behind, and your front overhead lights mount to has at least three. One below behind the driver seat.
Then he got two here, one in the middle one behind the passenger seat.
If you haven't noticed already, some of these are bigger ones, and some of them are slightly smaller, but in the end they're all equally difficult to get out. You going to need some needle nose pliers and a pry tool and it's going to be a bitch to get it out, but once you do, you might as well throw it away like I did because you're never going to get it back in. :facepalm:
Here's the sport bar / roll bar on the driver side rear door... Another big one and a small one.
If yours was sitting underneath the driver seat or behind it, chances are it fell from the driver side roll bar. It might also be an extra one. I mean maybe the guy who installed them in the factory had One fell out of his hand, he couldn't find it he put another one in and just left it there until you found it. That sort of thing definitely happens. When I got my Jeep, I found a screw underneath my carpet that didn't go to anything. My dad was saying that some guy at the factory probably dropped it couldn't find it, put another screw in and left it for me to find. 🤷‍♂️
Should be easy enough to figure out if one of your trim screws isn't actually attached to anything. Look at all your trim pieces in the roof area, see if any of them are missing a screw. If none of them are missing a screw, grab you the right size torx bit, and tighten them all, if any of them are loose and spin clockwise forever, there's probably no clip in there.
@Tredsdert youve unlocked a new form of OCD for me. There is 100% a random screw somewhere that I can hear rolling around underneath either my carpet or the floor itself when I turn.
3arl0fBruce
Rob
Northern VA
'23 Wrangler JLUR MT - Earl
No but what do you mean by panel? Could it be from that plastic piece next to the door where the door wires are stored?
You may be correct. I think there are two clips each on the b-pillar door wiring disconnect panels for the rear doors in a JLU
