jksams
- Sam
- Feb 20, 2024
- Las Vegas, Nevada
- 2008 Jeep wrangler jk, 2018 Jeep wrangler jl
I have a 2018 3.6l JL Rubicon. We were out on the trail and were cruising in 2WD with the sway bar disconnected ( I have the taser jl mini with the swaykill so we were cruising at about 30-40 mph for like 1-2 miles down the trail, which has never caused any issues in the past). We got to the start of the obstacles so we shifted into 4High and drove down the trail another .5 miles or so with no issues. As soon as we shifted into 4Low and hit 3rd gear the Serv. 4WD light came on and the sway bar reconnected and the dash said all electronic traction devices were unavailable. On the dash it would no longer show which mode the transfer case was in. We turned it off and back on and it all worked great until it hit 3rd gear again and all the lights and warnings came back on. So we decided to turn around and head home in 2WD. On the way back it worked fine and didn't throw any lights or warnings. I read that it might just be dirty wheel speed sensors so I cleaned them real well and inspected my wiring and found no obvious issues. I got back in and went to see if it fixed and it showed all the same lights and warning as soon as I shifted out of 2WD. I tried to turn it off and on again and it continued to show all the lights and not show which mode the transfer case was in. I drove it back parked it and now it is throwing 5 different codes.
P1DB6-00 -Vehicle Speed Signal Performance
P215C-00 -Output Shaft Wheel Speed Correlation
u1514-87 -Engine Controller Secret Code Missing
U0403-00 -Implausible Data Received from Transfer Case
C1403-92 -Transfer Case Ranger Position Sensor Performance
Im at a loss and I'm not sure what to do or where to start. I really don't want to take it to a dealership so any guidance would be greatly appreciated
