c3nixon
Anyone else run into an issue with multiple diagnostic codes coming on and disabling the 4WD?
I have:
PCM U0418 Implausible Data Received from Brake System control Module 1
PCM U1409 Implausible Left Front Wheel Speed Signal Received
ABS C00311D Left Front Wheel Speed Sensor-Curcuit Current out of Range
DTCM U041500 Invalid Data Received from Anti-Lock Brake System (ABS) Control Module "A"
BCM B230311 Wiper Park Switch Input-Circuit Short to Ground
Recently had a 3.5inch lift and 37" tires put on. ABS Light and Traction Control Light are on - also 4WD Service light which is stopping me from being able to shift into 4WD. NOTE: Issues did not exist PRIOR to lift. 37" tires were on and in use for 4 days BEFORE the lift. Front left Wheel Speed Sensor has been replaced and still same error code.
Thoughts...?
I have:
Thoughts...?
