Mud stain removal, buffing compound?
J0E
J0e
Hawaii, MT, SLC, NYC
bt39.com
2021 JLR, 05 LJR on 43s
Hawaii is famous for red staining mud. I crawl through the mud and avoid it as much as possible and pressure wash my JLR as soon as I get home. The 3,300 PSI washer takes of 99% of the mud, but I still end up with many small stains. I've tried every type of solvent and what works best is a good car washing soap and a microfiber towel, but that takes 15 minutes of intense elbow grease to remove a 1/4" by 2" stain. I'm going to try a buffer and compound. The Buffing Compound recommendation? thread is looking for a compound for small smudges and scratches I want to buff out.
I was thinking of using microfiber and foam pads and the least abrasive possible compound, but maybe just soap and a wool pad would work best.
I misread your question, for light scratches you can get away with glazes below
Both of these will take care of it, for harder areas the 3m will blend that nicely
https://www.amazon.com/3M-39007-Hand-Glaze-16/dp/B0002NUNIO?th=1
I also like to use https://www.amazon.com/Mothers-01716-Ceramic-Polish-Coat/dp/B07YSW49LT
For tougher scratches and really needing to work the paint buffing and using a buffer
https://www.amazon.com/3M-Perfect-Rubbing-Compound-36060-6PK/dp/B00DCMM48E
then followed by the one of the glazes above etc then wax..
Remorseless
NC
Holier Than Thou Internet Bully, Part-Time Online Boy Scout, Full-Time Arson Enthusiast, Napalm Compatible, Not Only The Guy Who Defines What A Jeep Guy Is, But Also The Guy Who Defines What A Jeep Thing Is, Guy Who Has The Authority To Do That, Dictator of What Is or Is Not 'Hard Wheeling', Arbiter of What Counts as an Obstacle, Weak Ass Bitch Identification Agent, Definitive BBQ Definer, Guy Who Actually Used a Winch Once
NC has similar mud. Nothing will remove these stains. Years of pressure washing, scrubbing, wiping, UV exposure, etc. and my JK left me with mud stains in the plastic that it received 10 years prior. Save your money and time and figure out how to be zen with it, IMO.
WagzDad
Carroll
South Louisiana
First try Maguires Scratch X
  • Like
Reactions: J0E
CopperMtnGuy
Ross
Wisconsin
2018 JL Wrangler, 2005 KJ
What is in the mud? I know a lot of the red/orange mud up in Minnesota, for example, is rich in iron which gives it the color. I use an iron remover to get it out and it works great.
  • Like
Reactions: J0E
WagzDad
Carroll
South Louisiana
J0E
J0E
J0e
bt39.com
As I said, elbow grease works and gets it all out. I was looking for something faster. My 3,300 PSI power sprayer removes 97% of it.
You want to get some iron remover detailing spray. That will pull it out of the paint.
https://gtechniq.com/shop/auto/wash...MIoqbE6orZ-gIV0xF9Ch2eoQm8EAAYBCAAEgLbcvD_BwE
Iron is a likely culprit, but shipping to Hawaii is too much to test this approach
Jeep Wrangler JL Mud stain removal, buffing compound? 1665536900502
Adam's Iron Remover (16oz) - Iron Out Fallout Rust Remover Spray for Car Detailing
I'll try that, free shipping on Amazon
