Buffing Compound recommendation?
Rustynail11
Mansfield, TX
2022 Wrangler JLU Rubicon
I have some small smudges and scratches I want to buff out. Any recommendation on what compound/polish to use?
ChuckQue
Charles
www.stayreadyoutdoors.com
2022 JLURD
Owner of Stay Ready Outdoors
I know there’s super high speed low drag pro detailed stuff out there some will recommend, but I personally like Adam’s One Step polish for lighter duty work. Did my whole F-350 with it and a yellow pad, came out pretty damn good.
Maverick909
I.E.
www.instagram.com
good ol 3M still has some of the better stuff. I do like The Chemical Guys stuff too
whitechocolate
Fl
2021 JL 80th Edition
3M compound and polishes
I misread your question, for light scratches you can get away with glazes below
Both of these will take care of it, for harder areas the 3m will blend that nicely
https://www.amazon.com/3M-39007-Hand-Glaze-16/dp/B0002NUNIO?th=1
I also like to use https://www.amazon.com/Mothers-01716-Ceramic-Polish-Coat/dp/B07YSW49LT
For tougher scratches and really needing to work the paint buffing and using a buffer
https://www.amazon.com/3M-Perfect-Rubbing-Compound-36060-6PK/dp/B00DCMM48E
then followed by the one of the glazes above etc then wax..
John VonJeep
Middle of Nowhere
Many
Start with a very light compound and work your way to heavier compounds if needed. The application technique usually matters more than the compound. A quality orbital buffer (with a treated pad and very light pressure) is best.
You can mess up your paint trying to buff stuff out.
https://www.drbeasleys.com/blog/2012/08/24/the-over-polishing-problem
Read up on technique and proceed carefully. Chemical Guys has a good video series.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
After playing with the more expensive stuff, I just use good old Megs stuff now.
Tncdrew
Tom
East Tennessee
2022 JL Willys, 3.6L - 8spd
For light scratches/swirl marks, I've always had good luck with Meguiars Ultimate Compound. Works pretty good on clear coat finishes.
