Mud flap recommendation?
wazzabie
Jeep JL
What mud flaps are you using. I don't want to do any drilling. Weathertech makes some at $150 that I'm looking at.
TheBirdie72
Rhode Island
2021 Jeep Wrangler Freedom Edition 2 Door
I have weather-tech and no complaints whatsoever. Easy to install and look good / work well.
Rokblokz usually tend to be highest rated around here, though. Especially if easily removing them is important to you.
GeorgeYJ2JL
George
Camaro ZL1, M3, Ram 1500, Willys JL
I purchased the weather tech. Here is how they look. Overall OK. But be careful to catch both parts of the back bumper or they will not fit tightly
Jeep Wrangler JL Mud flap recommendation? IMG_5004
Jeep Wrangler JL Mud flap recommendation? IMG_5005
Jeep Wrangler JL Mud flap recommendation? IMG_5001
GeorgeYJ2JL
George
Here are some up close pictures of the weather tech and how the back bumper 2 parts have to slide in between the guide
Jeep Wrangler JL Mud flap recommendation? 1013415-54e5bff8229afbb28dc64efa735fc92f
Jeep Wrangler JL Mud flap recommendation? 1014421-a9ad3f56dc3366c34b3c4ba4b55676a
Jeep Wrangler JL Mud flap recommendation? 1013414-8b42ceb2af3c3e537952d51e41fe6c87
Jeep Wrangler JL Mud flap recommendation? 1013413-e76d5ae32374b82f348c3634aca6c0cc
Jeep Wrangler JL Mud flap recommendation? 1014419-a9ea78444311168773a25429b3121a10
Jeep Wrangler JL Mud flap recommendation? 1014418-29d7d99966d335b8f793d21f026d50ca
GeorgeYJ2JL
George
I also took some small strips of PPF and put that inbetween the rear bumper and the mudflaps so it wouldn't rub on the bumper should you ever have to take them off. The back bumper was tricky, until I noticed there was two parts and both parts had to slide into that guide for it to be tight.
GinaC
Gina
Newport, VT
2026 Willys 2.0T 2DR Hard Top in Mojito built for me!
I have the WeatherTech on my 2024 Willys 4xe and I really like them. They look OEM.
FYI, the dealership went to order them for my new 2026 Willys and only the front are available as of last week.
I have the safety and comfort groups and performance "step" rock rails on both vehicles.
Wbino
NJ
I used to have mudflaps on a couple of nice cars I had because I was worried about chipping the paint on the side. But ultimately they are more trouble than they are worth especially in the winter. The mudflap will grab all the ice and snow and become a solid chunk of ice that you need to pick off, because if you don't you'll get rubbing and a wobble in the vehicle.
Red Rubi 22
Michigan
2022 Rubicon 2 door
Rokblokz all day! Simple install and removal. I have never had a reason to remove them, except that one time I needed larger ones as my new rims pushed the tires out about an inch. They are fantastic.
vetygud
Michael
Nisswa, MN
2022 Jeep Willys 2 door Sarge
Retired LEO
I installed the WeatherTech on my 2022 Willys 2 door and they help to keep the slush, sand and mud off of the door hinges. They cut down considerably the slop to the sides and rear quarter panels. The fit and finish is great. Install was easy. I've always had good luck with WT.
Front
Jeep Wrangler JL Mud flap recommendation? WT RF
Rear
Jeep Wrangler JL Mud flap recommendation? WT RR
Blues Fan 30
St. Louis
Rokblokz on both ours. Super easy to remove when hitting the trails.
Opus
Midwest US
www.jlwranglerforums.com
As you see, OP it really comes down more to aesthetics and use-case. I have Weathertechs and agree with others that it looks more OEM. If I wheeled on a regular basis, though, I'd go with Rokblokz. They look a little more clunky to me, but they work and are easy to remove before you hit the trail.
X35
PA
2025 Wrangler Willys XR
Jeep Wrangler JL Mud flap recommendation? IMG_1278
wazzabie
Jeep JL
I may also try to make some custom mud flaps. I'm going more for function. If they fall off on a trail I would be ok with it. I'm tired of having to clean mud from the side of the Jeep.
tk1700
Tom
New Mexico
2021 JLUR, 2016 Tundra, 2025 Hyundai Palisade
Rok Blokz
Jeep Wrangler JL Mud flap recommendation? 20210502_081509-1
Jeep Wrangler JL Mud flap recommendation? 20210502_081520-1
