MPG improvement 2 gal per mi.
JEEP ISSUE
Bill
2019 Wrangler JL
2019 Wrangler JL 3.6. Your air-conditioning compressor is running more often then what you think. If it’s winter time, remove the fuse for your AC clutch (mine F18?)and you will see a gas improvement of 2 miles per gallon.
badge171
Frank
central NY
2022 wrangler JLU Rubicon , 1979 CJ 5
Fire Department Deputy Chief Retired
Defrost,
Hell I remember The CJ's, rag top, in upstate NY winters. baby in the back in a car seat couldn't even see her ,my wife had her so bundled up . Had that CJ-5 on defrost . More like my thumb going in a circle was the defroster. Defrost you say !!!
Redcanyon77
Yorktown, VA
2023 JL Rubicon FarOut Edition, diesel
Interesting. Might try that on my 3.0 just to see. I completely understand that my defroster might not be as effective. I would think I’d have some defrost just not as effective. Non-AC cars have defrost
jadmt
jeff
montana
you will still have your defrost but you will also have more fogging up inside than without it.
Powelligator
Parker, CO
2006 LJ Rubicon, 2022 JL Rubicon
Defrost,
Defrost in my old CJ-7 was a rag I carried with me. Good thing is that in a CJ you can cover the entire inside windshield with your right hand from the driver's seat.
Redcanyon77
Yorktown, VA
I guess that’s what I meant when I said I completely understand it wouldn’t be as effective.
dsgrey
Kevin
2019 JLU
Yep, owned one in my youth. Just blows hot air on the windshield with the humidity thus why you kept a rag on your dash to wipe the fog off the inside windshield.
Redcanyon77
Yorktown, VA
Unfortunately I did as well. Takes a little more finesse trying to find the sweet spot on the manual temperature adjustment. Makes you appreciate it though.
Redcanyon77
Yorktown, VA
If people do have success with it I suppose one could get creative and wire a manual on/off to one of the aux switches.
JEEP ISSUE
Bill
2019 Wrangler JL
I never had a defrost problem yet! I still have heat! And when it is cold it is dry! You do t need the A/C !
