Motor hesitation
wkirnberger
Bill
Arizona
2019 3.6 L Sahara JL
Retired Maintenance Technician
When at a stop light turns green I accelerate and the motor hesitates then moves. Also when city driving and accelerates it also pauses when passing !
GabeBoyTheGreat
Virginia
2018 JL Sport, 2025 JLU Willys
Test Engineer
What year and what engine?
GabeBoyTheGreat
Virginia
Test Engineer
2019 wrangler Sahara 3.6L V6 JL
Do you leave Electronic Start Stop enabled? If so, there will be a delay when trying to accelerate from a stop.
Heimkehr
Pennsylvania
2021 JLU 2.0T
Are you the original owner, meaning the hesitation started to occur only recently? Was there engine work and/or a repair performed that might've inadvertently contributed to the issue?
You'll need to provide the necessary context here.
wkirnberger
Bill
Arizona
Thanks for the suggestion, I live in Arizona so with the heat the start stop never works while the AC is running, I turned it off and so far it seems to have fixed the problem. I will drive more in the heat of the day! Thanks to all that made suggestions!
Bill
GabeBoyTheGreat
Virginia
Test Engineer
Bill
I am a bit confused. Are you saying that it was the Start/Stop causing the issue? And you disabled the Start/Stop by running the AC? You are aware that there is a button that disables Start/Stop, correct?
wkirnberger
Bill
Arizona
I disabled the start stop by pushing the button, living in Mesa Arizona in the summer time we run the AC whenever we are driving because of the extreme heat, therefore the start stop never works because if it did work it would shut the engine down and the air conditioner would not put out cool air!
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
Bill
That fixed the pauses while passing???
