Mopar lift with Fox Shocks
Terpsmandan
Penn Yan
Can anyone recommend a front shock to replace a failed shock on my 22 JLURD with a Mopar Fox lift?
Roky
Roky
I would not recommend mix matching shocks. Sometimes you can find the Fox 2.5s as takeoffs on eBay or social media marketplace…otherwise I’d replace all four . Whichever brand you choose make sure the compressed and extended length matches your Fox 2.5s ( front 17.5 comp. 26.25 ext…the. rear 19.25 comp. 28.5 ext…) this way you won’t have to mess with your bump stops…
Terpsmandan
Terpsmandan
Penn Yan
Thanks. I have a note to Fox asking for their recs on a substitute. Seems I can get a set of Bilsteins or Ranchos for the cost of two Fox front shocks.
dpike
New Jersey
'20 JLUR 3.6
I have the Ranchos on a 2" Clayton lift and they feel great.
Terpsmandan
Terpsmandan
Penn Yan
dpike
New Jersey
'20 JLUR 3.6
I think its at 5 front 6 rear. I'm a little heavier than most jeeps with a rtt and camp box in the boot. There's a link somewhere for a 3d printed "key" that fits over the adjuster dial, it's pretty handy to have since the dial is a bit primitive.
Terpsmandan
Terpsmandan
Penn Yan
Thanks. Seem to be headed that way.
dpike
New Jersey
'20 JLUR 3.6
FYI not sure if it makes a difference but the "boot"/shield is pre installed red hard plastic and doesn't look replaceable if that's going to kill your blue theme. It's probably pretty easy to paint tho.
Terpsmandan
Terpsmandan
Penn Yan
Thanks. I just want them to work. Pretty annoyed that one has failed so soon.
Terpsmandan
Terpsmandan
Penn Yan
So I figured it out. Her 12 JLURD id Granite with rad accents all around and I put F rated 35x12.5x18's on it when we did the lift, so I am going to give her the Ranchos to help out the ride and take her Fox shocks off and replace my RF. Thanks for your help.
