Miles between oil change: A data point
smokeythecat
2021 Willys Sport 2-door, 2019 Mini Cooper S
I see lots of threads about how often to change oil, but most posts seem to be based on gut feelings. As an experiment I decided to use the Jeep's oil monitor as my guide since I see a lot of scoffing at that metric. I didn't let it get all the way down to zero, but I did get it down to 1%. This meant an oil change after 8820 miles.
An oil sample was sent to Blackstone. It's nice having data to take the ambiguity out of a decision. I'm going to take the advice and go 10,000 miles next round. But I might be giving my Jeep calcium supplements.
Jeep Wrangler JL Miles between oil change: A data point THE WILLYS-241102
azwjowner
Phoenix
Which Mobil1 0w20 variety did you use?
rk911
Rich
DuPage County IL
'23 Wrangler Sport 2D, '10 Liberty, '46 Willys
Retired and loving it!
IMO you can't change the oil too frequently. When I was still working I changed oil every 5000-mi, roughly every 50-days. These days it"s every 6-mos. roughly 1K-2K miles.
smokeythecat
smokeythecat
It's hard to tell if you are joking or not. The whole idea was to be data driven and not just going with your gut.
Dave K
cheshire ct
2018 Wrangler Sahara Unlimited
Great idea, thanx for sharing
Hard Rock Jeep
Richard
Nashville
2016 JKUR HR, 2022 JLUR 2.0, 2022 JLUR Diesel
Thank you for doing this. That is quite informative. Oils have changed a lot since the days of 3000 miles. By the way, how much did this test cost?
NWJeepr
Twin Peaks
2025 Wrangler 2-door
I see no value in exceeding the manufacturer's oil life change recommendations while under warranty, and certainly not in paying for tests proving that I can do so. Each to their own...
Come to think of it, I've changed the oil in my Jeep 4 times in 6k since new. lol.
Bandit59
Tennessee
2021 Jeep Wrangler 4xe
Good info. But I will stay at 5-6k between changes. For me 4 changes a year
YBABRAT
VIRGINIA
2019 2 Door Rubicon X Wannabe
None... but it pays well.
I'm running Valvoline Restore & Protect 0w-20. I have watched a Valvoline plug video that explained a few pointers with any oil and the differences with their new product. Flash point and a ability to clean. Even though many oils claim above 5K miles, they recommend 5k. There is a balance higher flash point less stable breakdown linearity and visa versa.
So far with over 86k on odo, it has cleaned fairly well. Added roughly .5psi to oil pressure and probably helped with my MPG. There has been claims by independent users, that oil consumption is reduced because of it. I never seen any consumption since ownership with 82k on odo.
The key is oil changes at 5k... no matter how good your oil is. If you run 7k oil, think of it as a cushion to when you are able to perform an oil change.
smokeythecat
smokeythecat
I have forgotten the exact amount, but I think it was in the $36 range. It's $10 more if you want to test for any additives.
Old Dogger
Cave Creek Arizona
It is nice to see some oil samples, and what they show. But I have always changed my engine oil, every six months. That use to average between 3000 to 5000 miles per change. Now that I am retired, I don't drive that many miles any more. So I am averaging about 2000 miles per six month change. As for me, engine oil is cheap, so I will stay on my schedule. But everybody to their own. I have also always used 5W30 viscosity in all of our 3.6 engines. I feel more comfortable doing this is hot as hell phoenix AZ.
LDSSILLS
Larry
Midwest
2021 JL Rubicon 4Dooor
I use this rule. And its based on breakdown of oil detergents and filter effectiveness.
Below 20,000 miles I like to change it every 3,000 miles. Reason is the engine is new and todays smaller filter needs to remove any left over metal from internal engine parts. Yes its expensive if you use a synthetics but you will be thankful because metal parts are getting caught and removed.
After 20,000 miles to warranty expiration I go to every 5,000 miles or 4 months. . Primarily, because I believe detergents start to breakdown around that mark. Those detergents are important as the remove carbon deposits which then go into the filter.
Once my warranty is expired I go to "non" synthetic oil and change every 3,000 miles again. Bottomline if you read the bottles of synthetic and non synthetic oils they all meet the same ASME standards. So why waste money on synthetic.
Trust me its a great feeling when you have more than 100,000 on that engine and you pull the dipstick to find its hard to read because your oil is as clear as it was from the bottle.
