Ah! Less work thenregular kit comes with uppers.
Why would that kit ride rougher due to LCA angle? Unless you are using drop brackets or long arms the angle is going too be similar whether it is an adjustable LCA or not.That kit rides rougher due to the lca angle.
hey. Who made your signs? I’m getting my JLUR next month (hopefully lol) on order and my realtor magnet signs from the JKU aren’t gonna work.Metalcloak 3.5 Installed so far so good I won’t have a chance to off-road it for a month or so but for a big lift and large tires it still drives really well.![]()
This isn't a hard concept to understand. Every degree past parallel makes the front wheels want to hop rather than articulate. In the case of the short arm kit on my JK it netted 4.5 inches and the angles were well above stock. Combine that with a D or E rated 35/37 its going to ride rougher than a kit with corrected angles via drop bracket or long arm kit.Why would that kit ride rougher due to LCA angle? Unless you are using drop brackets or long arms the angle is going too be similar whether it is an adjustable LCA or not.
That’s why I said “unless you are using drop brackets or long arms”.This isn't a hard concept to understand. Every degree past parallel makes the front wheels want to hop rather than articulate. In the case of the short arm kit on my JK it netted 4.5 inches and the angles were well above stock. Combine that with a D or E rated 35/37 its going to ride rougher than a kit with corrected angles via drop bracket or long arm kit.
Yes but the difference being its a 3.5 inch kit with short arms and nets closer to to 4 -4.5depending on How your rig is set up. Vs say a mopar 2 inch if indeed you net only 2 inches that difference is negligible as it relates to lca angle.That’s why I said “unless you are using drop brackets or long arms”.
According to MC instructions you set the LCA to 24” (same as stock) and adjust the UCA shorter, that should get you above 6° caster. Then the cya comes in and they say that should be close enough to get you to an alignment shop. I’ve used those measurements a ton unless I have a specific reason I want to move the axle forward and it’s been great this kit rides terrific. The only reason this would ride worse is the bushings on the MC LCA are superior.This isn't a hard concept to understand. Every degree past parallel makes the front wheels want to hop rather than articulate. In the case of the short arm kit on my JK it netted 4.5 inches and the angles were well above stock. Combine that with a D or E rated 35/37 its going to ride rougher than a kit with corrected angles via drop bracket or long arm kit.
I’m debating full game changer 3.5 or the dual rate. Will likely go full game changer.According to MC instructions you set the LCA to 24” (same as stock) and adjust the UCA shorter, that should get you above 6° caster. Then the cya comes in and they say that should be close enough to get you to an alignment shop. I’ve used those measurements a ton unless I have a specific reason I want to move the axle forward and it’s been great this kit rides terrific. The only reason this would ride worse is the bushings on the MC LCA are superior.
Brett
