Terpsmandan
I got the PLC2 installed. I had to remove the entire panel and grind a little plastic off the backside. I also reset the amps with my o-scope. As I suspected, there was a lot of room in the gain settings. I used the settings that @Hpc3 sent which had the rear channel turned down farther than the front. Then with the scope, I maxed the gains with a -9db 1khz test tone with the HU volume at max (38). Also removed the AmpPro and ran the amp remote turn on across the dash. See how it all works tomorrow morning.
