Manual Transmission - Issues shifting into 1st & Reverse (Compilation thread)
OldGuyNewJeep
Don
CT
ACT,
Will also mention that this is 2nd kit i got from them, because someone earlier claims to have trouble free experience with "revised" version.
By the time my ACT hit 10,000 miles I was in your exact boat. Basically, it became undrivable.
My CFII with internal slave/throwout just crossed 10,000 miles and is eons better than my ACT was. I very rarely get a little resistance to 1st at a red light, and easily overcome it.
My CFII has never gotten stuck in gear like my ACT would.
Also, my ACT would behave for a short time after pressure bleeding.
All of this is to say I think @Toycrusher has identified the issue common across all available JL clutches, BUT I firmly believe ACT has an additional issue of stock hydraulics not being up to task.
We shall see what another 10,000 miles looks like, but as of now I have no regrets on swapping to the CFII.
Reflektr
Travis
Illinois
2025 JLU Willys
Equipment mechanic
Forgive my ignorance, but how does that work exactly with an internal slave cylinder? I’ve only owned manual vehicles with an external slave. I’ve also never had any of my other manual vehicles ever give me a lick of trouble either…. 🤣
Toycrusher
JLUR
Basically the slave cylinder is a donut around the input shaft that pushes directly on the throwout bearing rather than using a fork.
Only downside is transmission needs to be slid back if you ever need to service it.
Jeep Wrangler JL Manual Transmission - Issues shifting into 1st & Reverse (Compilation thread) 20260102_134816
Jeep Wrangler JL Manual Transmission - Issues shifting into 1st & Reverse (Compilation thread) 20260102_134810
OldGuyNewJeep
Don
CT
Only downside
Another potential downside is it leaking. When McLeod first announced on our forum, an early adopter had his fail twice while they were dialing-in their design. Big mess that requires dropping the whole transmission, if it happens.
At the time, I was a vocal critic. But here I am with a similar design and so far so good. 🤷‍♂️
Reflektr
Travis
Illinois
2025 JLU Willys
Equipment mechanic
Ohh ok I see now. Thanks for posting the pictures. Yeah, I’m not so sure that’s a risk I’m willing to take just yet. I guess if they got it dialed in it would be alright. I’m kind of surprised there’s not a more beefy option for external hydraulics.
CorvZ061
Travis
Amarillo, TX
'24 JLUR 6MT
Most manual transmissions out there on modern vehicles are this way, the external slave is actually far less common and I think the Jeep is the only company using an external slave at this point.
Reflektr
Travis
Illinois
2025 JLU Willys
Equipment mechanic
That would explain a lot because all of my manual transmission vehicles were much older.
RubiSc0tt
Upstate NY
2019 JLUR in Punk'n Orange
Turn Wrenches/ Write code
I fell down a rabbit hole researching this for a few months, but it got complicated quick for me: different physical shapes and attachment points, then the pressure they all put out, etc. I asked a couple shops I know that work on drag cars and off road Jeeps. They didn’t know of anything that would work with the AL6 in the JL. I think part of it is that, but also this isn’t a widely used manual in racing/ aftermarket offroad applications. Just my guess.
Reflektr
Travis
Illinois
2025 JLU Willys
Equipment mechanic
This whole shootin’ match really has me wondering what other manual transmission and clutch assemblies will work in the JL. I refuse to accept the whole “The manual is dead. Trade it off on an automatic or you’re just boned” mentality. Not when they’re throwing Hellcat engines in these things like they’re Reese’s Pieces. I mean I’ve built some pretty rad shit back in the day when the odds weren’t exactly in my favor. When I had little to no money and all I had was time. Something better has to be possible.
RubiSc0tt
Upstate NY
I've been thinking a lot about this lately, but based on some of the info in this thread, it sounds like it would be well above my level of comprehension and allotted time.
So for me, it's probably replace the clutch (again), and cross my fingers, and start saving for that 392 I've been chasing.
RubiSc0tt
Upstate NY
So adding to this thread:
I had an interesting convo with my mechanic. He called several companies and talked to them about the whole clutch situation. In his opinion of working with and on performance and off road vehicles- McLeod seems to be the ticket, based on the design and their knowledge of the subject.
He also said told me some of the stuff McLeod has been looking in to- basically, they seem to think there is a correlation between People with larger tires running sub-optimal axle gearing and a much higher failure rate, logic being it takes more slipping of the clutch to get/ keep things moving.
Food for thought, if nothing else.
SadRobot
SadRobot
Los Angeles
2025 Prius LE
Interesting theory. What did he consider sub-optimal? I had 4.88 gears with 37s.
Also wild we're still talking about all of this 74 pages later. I guess I should edit my original post with the final conclusion that I sold my Jeep so I wouldn't have to deal with the shifter locking up again.
RubiSc0tt
Upstate NY
Well, I've got 37" tires with 4.10's. The guy at McLeod basically said "37's, he should be on 5.13's!" to which my Mechanic replied "Yes, but It's a daily driver he drives on the highway. 4.88's would probably be top". I believe the guy from McLeod said most of the users they had worked with that experienced a failure were 4.56 or lower. He made the point that if Jeep is doing the XR package with 4.88's and 35's w/ the manual transmission and V6 (per the builder on the website) and that is considered "optimal" by the OEM, then it would end up having to be a numerically higher (lower) gear ratio for 37's.
I don't know the mathematics and engineering behind it, but the logic checks out i guess.
SadRobot
SadRobot
Los Angeles
2025 Prius LE
I was thinking of maybe going 5.13s if I decided to get new axles for mine. I don't regret the decision I made to sell though. 2k miles after re-install the shifter is locking up again which was what I was worried about if I threw money into new axles.
The new owner plans to do some troubleshooting and modifications to see if they can come up with their own fix to the clutch problem.
