58Willys
- Geoff
- Jan 2, 2022
- Western Washington
- 2018 JL Sport
Everything you’ve said here points to the clutch not fully disengaging.Throwing in my own anecdotes in case it helps with identifying the issue(s).
I had the ACT pro mass installed June 2023, about 13k miles ago.
Started experiencing first and second gear lockout approximately 2 months ago. Behavior is similar to the 1st gear lockout when going too fast.
I noticed that once the lockout starts happening, it will lock me out if I spend ANY time in neutral with foot off the clutch.
If I come to a stop and keep the clutch depressed the entire time, I have no issues entering first gear. (This is one of my methods to bypass the issue)
However, as soon as I release the clutch and depress it again, I am locked out.
When I am locked out, I also have difficulty trying 3rd gear. I am able to shift into 4, and that seems to release 1 and 2. (This is my other method of bypassing the issue)
It seems that sometimes it locks me IN gear, where it becomes challenging to shift to neutral. Releasing the clutch a bit seems to alleviate this when it happens.
When locked IN GEAR, I have also noticed my Jeep moving forward even with the clutch fully depressed. I also notice a groaning sound when this happens at a stop, as if it is trying to move forward but can’t because my foot is on the brake.
This could be weak or malfunctioning hydraulics , or a mis-aligned disk or other mis-alignment such as main shaft alignment, or excessive crank/flywheel lateral runout.
