Manual Rubicon: Engine speed vs. Road speed
twodoorfour
Pacific Northwest
2018 Tacoma TRD OR, 2018 Subaru Outback Limited
Could someone with a manual transmission Rubicon let me know what the average RPMs are at these given speeds in 6th gear?
Flat ground without major wind playing a factor is helpful.
55 mph
65 mph
75 mph
And 80 mph
redracer
Robert
Manteca, CA
2023 4xe Rubicon
55 mph
65 mph
75 mph
And 80 mph
55 in 6th gear is a no go. It’s way too low of rpm. It won’t accelerate and sounds horrible if you try.
65 in 6th is right around 2000 rpm. I don’t like to do this unless I’m trying for economy on flat highway. My rule is 6th is for 70+
75 I’ll have to remember to look.
And I don’t do 80. It’s a Jeep.
This is an all stock JLUR 6 speed with the OE 285 ko2’s
OldGuyNewJeep
Don
CT
I shift to 6th around 65mph. It’s a second overdrive, and I downshift straight to 4th if I need to accelerate or climb a hill.
RPMs aren’t going to move much for your listed speeds. Just under 2k at 55 and it might lug. 2k or slightly over for the rest, though I rarely hit 80 (too fast for a Wrangler, IMO). 65-70 is the sweet spot for highway cruising in 6th, for me.
Not much difference between 5th and 6th as has been discussed at length, already. Even so, I use it every day because why not?
Edit: I just drove to gym and watched the tachometer on my way. I actually shifted to 6th at 55 (naturally/unconsciously). RPM was 1500. No lugging unless I stomped the pedal down. At 65 RPM was about 1900. I couldn’t get going faster than that due to traffic.
Note that I have a stock 2dr.
twodoorfour
Pacific Northwest
Is that a Rubicon or Sport? And thanks for the info!
I don’t plan to go 80+ often, but 70-75 is very normal where I am and I don’t want to be super revvy on everyday highway speeds.
OldGuyNewJeep
Don
CT
2dr Rubicon.
