Lowest tire pressure without beadlocks
anotheraznguy
Tracy California
Mojito JLUR
Just wanted to see what everyone around here is running in terms of pressure without beadlocks
I have 37x12.5 tires on a 9 inch wheel
The tires i am using are patagonia MT's and so far i've gone down to 18 psi. In the pic below i am at 18 psi with all the weight loaded on driver front. If you notice, the tire is not bulging out at all and almost looks fully inflated. Just trying to see if i should bring it down to as low as 10 psi.
Jeep Wrangler JL Lowest tire pressure without beadlocks IrVgYmm
wpwood3
Atlanta
2018 JLUR Ocean Blue, 2010 Toyota Sequoia
You may find this video on YouTube informative:
Talks about your tire with and without bead locks.
Mojito Mojo
Doug
Apache Junction, AZ and North Mankato, MN
2018 Mojito Rubicon JLU, 2004 Corvette convertible, 2015 HD Road Glide, 2014 Indian Chief Vintage
Would your decision on tire pressure change if you were running C rated sidewall tires vs. E rated?
Mojito Mojo
Doug
The milestar's are not E-Rated. They are D-Rated.
But just speaking generally, would it be better to keep a little more air in a softer sidewall tire?
Tech Tim
Summit Sponsor (Level 3)
Tim
Poulsbo, WA
4x4 of all kinds
It really depends on the shape of the bead of the wheel and how tight the tire bead is.
Right off the bat, I'd say 10-11 psi you should be fine, most tires on most rims can handle that.
The Patagonias seem to be pretty tight on the wheel, they might allow you to go a bit more, but you'll need to play with them and see.
silverbullet
Keaton
Dallas, Tx
2015 JKU, 2018 JLU Rubi
I run about 11-12 psi on 37x12.50r17 with a 8.5" wide wheel. Been close to rolling a bead but has not happened yet with many miles of wheeling on them.
blnewt
New Mexico
Just ask @cosine he knows!
Shenanigans
NorCal
JLU Rubi
What about the stock Rubicon setup? What should I target there?
Geoff
This stock rubicon setup is golden down to 12 lbs for rocks.
On 37x12.50x17 on a 9” wheel I’ve been fine at 10 all day.
38.5”x14.5x15 tsl on 12” wheels felt like street pressure when aired down to 10lbs on the trail. Those I ran at 8 lbs just to get the sidewalk to flex.
ive ran numerous other setups, but the point is, with different wheels and different tires, it just takes some experimenting.
LincolnSixAlpha
Arizona
about 1/2 what's recommended for your wheel. I won't dip below 15, usually around 18.
Tunesoul
Kirk
1999 Jeep Wrangler Sport, 2012 Subaru Outback, 2018 Ocean Blue JLUR
Owner of a Mobile Auto Paint Touch Up Co.
I did a snow run a couple of weeks ago in my JLUR with stock tires and wheels running them at 13lbs without any issues.
