19 JLUR Bright Whit3
Hey all, just wanted to let you folks know that when removing the yoke at the transfer case, the nut was a bit more than finger tight. The time it took to put a ratchet on the socket, the weight of the ratchet spun the nut loose. Very odd. Never less, I took care of the weeping front pinion seal and swapped out my front driveshaft with a Adams 1350. The 1350 U joints don't appear greaseable. The slide had a zerk fitting which I'm sure I'll shear off on some rocks. Thanks to fellow member @Amerxon555666 for a good deal on the front DS. I will be swapping the rear DS tomorrow.
Both OEM DSs will be in the for sale forum if your looking for spares.
Front Pinion Seal used : Mopar 68400358AA
Thanks for stopping by.
