Lightest weight wheels?
ItsNo4RE
NJ
21 JLU Willys/17 Ram 1500
Ok guys, so this eco weight thing has me looking like a cracked out hypermiller! I'm going full aluminum to cut down on weight... need the lightest possible wheel set that could accommodate a 37" tire although ill likely only go 35s...just in case
Dc7o2
Las Vegas
2020 wrangler unlimited rubicon recon
Venomrex VR501 17x9 at 24lbs each -6 offset 5.5 backspacing. available in black, gray, and bronze .
Jeep Wrangler JL Lightest weight wheels? 73B1540D-FF7F-4C5D-AEB7-A06FED28E80D
Jeep Wrangler JL Lightest weight wheels? FF930D21-B47F-47CC-A0D4-506A5650426C
blnewt
New Mexico
Just ask @cosine he knows!
beaups
Sean
Ohio
2020 JL
Keep in mind that, especially when running large tires, wheel weight has very little impact on efficiency or power. The closer the weight is to the center, the less it matters (linear versus angular velocity etc). You are much better off saving weight on the tires.
ItsNo4RE
ItsNo4RE
NJ
I'm just cutting weight where I can and adding weight where I need to... knowing the extra weight of the diesel, im just cutting like a ho who ain't been paid
dflick
Daniel
Tomball, TX
2016 Jeep and 2022 Jeep
Reviving this thread. We have a 23 diesel and looking at Metal Cloak for the lift but I want everything else as light as possible. Any suggestions for aluminum armor for the body and what else can I trade out to shave lbs? My goal is to Simplify and add lightness as Mr. Chapman would say.
Aonarch
Mike Hawk
North GA / MT
'25 JLUR '41, '24 F-150 V8 4x4, '22 Mach 1 6MT
Motorsports Engineer
Artec Aluminum skids, aluminum front stubby bumper. 11" wide tires, light weight wheels (Sub 25 lbs), lightweight winch (Carbon brand, Sherpa brand, etc). Possible spare tire delete and just keep sidewall patches and plugs on hand. Other than that there isn't a ton you can do besides don't add heavy mods. Add only what you need, not what you think you might need. So many people add these huge bumpers, skids, tire carriers, crazy heavy steering components, 37s, racks, etc only to tour around on gravel roads.
