Lightest weight wheels?
ItsNo4RE
NJ
21 JLU Willys/17 Ram 1500
Ok guys, so this eco weight thing has me looking like a cracked out hypermiller! I'm going full aluminum to cut down on weight... need the lightest possible wheel set that could accommodate a 37" tire although ill likely only go 35s...just in case
aro
2020 JLUR
Pro Comp 7069, about 22 lbs. They poke out a little, which I'm not crazy about, but I got them because they were the lightest I could find,
Dc7o2
Las Vegas
2020 wrangler unlimited rubicon recon
Venomrex VR501 17x9 at 24lbs each -6 offset 5.5 backspacing. available in black, gray, and bronze .
Jeep Wrangler JL Lightest weight wheels? 73B1540D-FF7F-4C5D-AEB7-A06FED28E80D
Jeep Wrangler JL Lightest weight wheels? FF930D21-B47F-47CC-A0D4-506A5650426C
blnewt
New Mexico
Just ask @cosine he knows!
beaups
Sean
Ohio
2020 JL
Keep in mind that, especially when running large tires, wheel weight has very little impact on efficiency or power. The closer the weight is to the center, the less it matters (linear versus angular velocity etc). You are much better off saving weight on the tires.
ItsNo4RE
ItsNo4RE
NJ
I'm just cutting weight where I can and adding weight where I need to... knowing the extra weight of the diesel, im just cutting like a ho who ain't been paid
