Lift issues
ducatijosh
Josh
DFW
2022 Jeep Wrangler High Tide
Hello, I had a local shop install a Clayton Offroad 2.5” RideRight+ lift kit on my 2022 Wrangler High Tide (Xtreme Recon package).
Lift is great and i ended up getting around 3” above the XR height (which is supposedly a 1.5” lift)
Afterwards though I started getting a shimmy in the steering wheel which ended up getting death wobble about 5-6 times coming down the freeway on a colder 40 degree day morning.
I took it into the shop and they moved a bunch of stuff around but I’m pretty positive the front upper control arms were on the wrong sides, when they were putting them back on after testing I mentioned that they’re supposed to angle down and In not down and out and they said oh yeah and flipped them. Could this cause death wobble?
I also noticed they didn’t use a torque wrench for anything which seems to be a common theme with paid mechanics nowadays, how big of a deal do you think this is? Do I need to crack all the bolts loose and torque them to spec? Or is it as long as they aren’t too loose it’s probably fine?
Thanks!
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
You can put a torque wrench on and make sure they are good.
Wobble gone?
ducatijosh
Josh
DFW
I haven’t had the wobble since I left. Was late in the day so they just put it all back together. That’s when I pointed out the control arms go on the other sides. All I’ve done is drive home though.
jhackathorne
Denver
'21 JLUR
Yeah… WTF on not torquing anything down. Are you sure? That’s a massive red flag to not trust them to do anything on any vehicle ever again. How unsafe. I’d check everything personally. Not being torqued would for sure cause DW.
ducatijosh
Josh
DFW
The guy was using an impact gun. He says as long as the bushing is pinched it’s good. Yeah…. I’ve seen several shops now that don’t use torque wrenches. I don’t get it. They just sling parts on.
Think it was the lack of proper torque? Too much or too little? Or theControl arms being on the wrong sides?
GATORB8
CLT NC
Meh, I wouldn’t stress that much about the torque wrench.
I don’t think it’s the direction of the CAs. Track bar bolts would be more likely. Really, my first thought would be balance.
firedude
Bret
AZ
2022 Rubicon XR 392 Stingray
Retired firefighter
I second torqueing everything to be sure. Front lowers take a lot of torque. Did they align it also? They do not sound like someone to use again.
GMONEY
Greg
Temecula California
23 2D Rubi Earl
I hate impacts
ducatijosh
Josh
DFW
Yeah I’ll retorque it all in the morning. They did do an alignment with an alignment rack.
58Willys
Geoff
Western Washington
2018 JL Sport
Your tech is an idiot.
Sgtrooster
NE Ohio
2022 JLUXR ,2021 Willys
do you have any before and after shots? , I am looking to put taller springs on my XR , not so much for lift but to get back to zero after bumper and winch.
ducatijosh
Josh
DFW
One before and two after. Front fenders went from 39” off the ground to 43” off the ground.
Jeep Wrangler JL Lift issues 33E56A1C-B953-49B3-8CB0-F9EE0431DC0B
Jeep Wrangler JL Lift issues A46AA434-2BFC-44DB-A6D7-A5283242BA41
Jeep Wrangler JL Lift issues 0B08DD34-2FFE-4144-AC0C-3D83ECFA1B6D
1Evil55
here
2018 Sport
That couldn't have been a real shop that would put LCA's on backwards.
ducatijosh
Josh
DFW
UCA's
jaymz
Jay
Inland Empire
2018 Rubicon Unlimited
I'd be more concerned about them not knowing which control arm goes where vs. not using a torque wrench. I'll probably get flamed, but I've been making a living as an auto tech for almost 4 decades and 99% of the time my torque wrench is only used when I'm building an engine or a differential. I've never had any sort of failure from too little or too much torque.
