Level 2 charging cable
TNVOLDoctor
NC
Trailhawk Elite and Wrangler
Hey everyone. My 2022 Sahara 4xe finally arrived. I already have a level 2 plug installed into our house. I now need a level 2 compatible cable to go from the Jeep to the wall. Any suggestions on brand etc., is appreciated.
TNVOLDoctor
NC
Thanks for the info.
N8213
Nathan
Hanahan, SC
21 4XE, Rivian R1S, R1200GS, 55 Stude truck
Do you have a charger already? Level 2 plug- assuming you mean a dryer outlet or similar nema outlet?
My l2 charger came with the cord that runs to the Jeep.
Terminex
Omaha
2021 JLUR 4XE
Fixing stupid....
The only level 2 chargers i recommend to friends are
  1. Chargepoint Flex (smart charger and there are rebates from MANY utility companies for this brand)
  2. Grizzle “dumb” charger (NOT the smart version as many have reported issues) the “dumb” version is well built and just plain works.
  3. Juicebox
  4. Mopar
Chargepoint is much better than the others for many reasons
-discounts or rebate from your utility company
-50 Amp capability in case you get another EV or plug in that supports higher charge rates (it is fine to have it set at 50A and plug in the 4XE, as the vehicle det
grizzle and mopar only support up to 32 Amp charge rates. (which is also the limit on the 4xe)
Juicebox does offer a 40 Amp version (but not the mopar branded, that is only 32)
Grimmjpr
Salt Lake City, UT
2024 JLUR 392
  3. Juicebox
  4. Mopar
The Grizzl-E is capable of up to 40 amps, and is adjustable at 16, 24, 32, 40 amps. Also its available in a NEMA 6-50 or a NEMA 14-50. Its a simple EVSE but I'm very happy with mine. My electric company was offering a 75% rebate up to $200 as a credit on the bill for the purchase of a EVSE, only requirements were the EVSE had to be new and UL listed. Other companies are doing other offers, check with your utility company.
I would only go with one that is UL listed or the equivalent spec in Canada. Some say they meet UL listing specs but unless they are actually UL listed I wouldn't get one.
BigMaCro
Moved to Iowa from Alaska
www.youtube.com
2021 JLU 4xe Rubicon
Carhauler
+1 Grizzl-e classic
I got a refurbished one for $400 something. It has very solid build quality and good heavy duty cable that I have confidence will still be flexible if I run outside in the cold. I'm also happy supporting a Canadian business.
